Recall #N242435631-03
I grow my own Avocados
I went to a Mexican joint with my wife and daughter tonight.....no green paste with my tamales and beans, but I did have some at Chili's last week with my fajitas, but I ate it on the side so it wouldn't ruin the steak and shrimp.
AS a result of this update, tow mode seems to stay on until you shut it off. At least for the day. I'll take it.
I thought that was always the case. Mine will start up in tow haul mode if shut it off that way.......I think.
I picked up a '22 ZR2 this weekend and I'm on the schedule at my local dealer for this update.
FWIW, a similar update was also called for my Colorado ZR2. It didn't take of first attempt, so the dealership needed to order a cable so the update would successfully complete. I didn't have any issues with the radio or controls in the truck, other than, occasionally, the audio source info wouldn't show on the dash and the forward/back audio controls weren't always working.
In my 1500, I've already noticed that phone call audio will briefly cut-out. I suspect this gateway control module will help address this issue. No other issues identified with my new-to-me truck.
Mine would reset beforehand after a few cycles.
So I did a little test today on mine. I noticed when I shut it off in TH for a short time (say an hour or less running errands) it always came back on at restart. However, later I shut it off for about 3 hours and then it either reset or it was due to three key cycles like you said.
Back in Biznaz fellas.
Yep. Custom built
I'd love to see how it actually works. Or how well it works. Do you have to touch the steering wheel at all? Or does it drive completely on its own? I'm assuming it uses the cameras to steer the truck?
