38 inch tires
Has any one tried to put on 38/13.5 tires on the hd zr2
Don't think I've seen this. I mounted up a 37x13.5 Toyo MT and it was close to rubbing on the UCAs with stock +32 mm offset Bison wheels.
If you try this, you'll need 0 or +12mm offset wheels. Should be enough clearance if you crank up torsion bars or level it.
I just added new tires 2 weeks ago... went with 37x12.50 Nitto RG on my stock Bison wheels. I almost went with a 38x13.50R18 RG just to be different and rag my buddies I had bigger tires but they were not easily available... And also what Axe said above. You can turn them on stock wheels but not without scrubbing and possible UCA issues.
YOLO
