6.6 HD Gasser Exhaust Tip Mod
I just had to FIX the Cheesy 3.5 inch factory exhaust exit pipe on the 6.6 Gasser HD. Went with the black 18 inch MBRP 6" Diameter exhaust tip. ("AXE's" and "securityguy's" installs inspired me, Thanks Guys!!!) I know its not a Diesel but it Looks so much better!!!! Very Easy install... Just a 3.5 to 5 inch universal exhaust adapter and the MBRP tip. Got everything on Amazon! I can send the Amazon links if interested.
Looks great, so still a little outward angle at the location you cut factory?
Ty! I cut right about 4 inches after the first bend from the tip end. I wanted it to run more straight out than curve behind the passenger side tire. So Yes... There is still a slight angle as it exits the back.
