22s vs 23s
dts1186
Kentucky
New member here. Looking to buy a 1500 ZR2 looking at used 2022 and 2023 models. Are there issues I should be on the lookout for that make one model year more reliable than the other. Was there anything wrong on the 2022s they fixed on the 2023 models?
pretty much both the same for gasser.
They say there were some paint issues on the 22's , maybe 23's ? none of the 24's I've seen including mine have any issues .
Same, the biggest issue is the c infotainment system is quirky and some of the electronic parts aren't reliable. If you draw the short straw and get one that has bad lifters or bad crank/rod bearings, then you have to deal with it. Get an add on warranty and shouldn't be an issue.
Went with a 2023! Thanks for the advice everyone.
