SAG
RMGREYZR2
New member
Houston
Does anyone know if airlift or Firestone makes an airbag system that will work for the ZR2, I see options for the trail boss but nothing for the ZR2?
Is this on a 1500 or HD?
1500:
HD:
The rear suspension is the same as a trail boss other than the fancy shocks.
And there is also RAS. A quick search will bring up plenty to read.
I hooked up to my new travel trailer with only about 700 pounds of tongue weight and my truck squatted 4 to 6 inches. It was very exaggerated so I put a new Kurt for P weight distribution hitch on the trailer and it didn’t seem to help very much so I’m thinking I may also need airbags
The 1500s are pretty soft. I was the one that started that first thread. WD hitch helps some, but they only have a payload of around 1300 pounds. You put a couple hundred pounds in the cab and hang another 700 off the bumper it's going to sag. Air bags make a big difference. Trailboss bags will fit, But they limit the up travel on a ZR2 and cause it to ride stiffer then stock. Especially when you hit bigger bumps. Not sure if any companies have came out with a ZR2 specific kit yet. If you at least run cradles with the bags and keep them at zero when you aren't towing. It will help some with the ride.
