- Aug 25, 2024
- 496
- 1,190
There is also the auto stop eliminator if you wanted to go that route.Yeah, don't wanna pay that much just to disable the Auto Stop. I'll just push the button when I start the truck.
You have a pretty damn good point. Didn't think i would have any of those problems, but you all see what happened. But I didn't pay much for it. Bought it from a forum member, so I didn't lose much. It was nobody's fault and it was worth a shot. In my case, it just didn't work out. No big deal. I'll just pass it along to someone else that can use it.when reading about @KLA's issues with the autostopstart module, it reminded me of the following from the AE039 PITA part i installed:
Our switch-based design avoids all of the negative side effects because it interacts with the vehicle exactly as GM intended. Don't be fooled by the hacks that:
Likely just a sales pitch, but KLA's issues with the other one makes me feel a bit better about the one I went with.
- Require warranty voiding software changes
- Drain the battery
- Disable Active Fuel Management (AFM)
- Keep the vehicle in "diagnostic mode" which disables the malfunction indicator light (check-engine light) and can interfere with airbag functionality. (Every GM diagnostic port auto start/stop device we've seen has this major flaw.)
- Hack the battery management system
- Interfere with remote start systems
- Sure our solution may take a few extra minutes to install, but avoiding all of the negative side effects is well worth it.
Things happen, a rock just came out of no where today and cracked my windshield. The day I am Supposed to get tinted SMH.You have a pretty damn good point. Didn't think i would have any of those problems, but you all see what happened. But I didn't pay much for it. Bought it from a forum member, so I didn't lose much. It was nobody's fault and it was worth a shot. In my case, it just didn't work out. No big deal. I'll just pass it along to someone else that can use it.
Yeah I had PPF applied to my last windshield to prevent this was considering doing it on the truck but was not fast enough.man that sucks. Least it was before you tinted and not after.
The windshields must be thin, mine cracked 2 weeks after I got my 2025 when an acorn fell out of a tree overhanging the road.Things happen, a rock just came out of no where today and cracked my windshield. The day I am Supposed to get tinted SMH.
I appreciate you sharing, I think I’ll hold off until I do a bit more research. Might just end up going the interior route.
Yeah it’s unfortunate. Although I did get hit pretty hard by that rock, it came flying across a freeway, I am assuming it’s from a bus.The windshields must be thin, mine cracked 2 weeks after I got my 2025 when an acorn fell out of a tree overhanging the road.
Sorry about the rock. Same thing happened to my 2015 Silverado. But it happened the very next morning after I bought it. Bought the truck, got home at 10pm, on my way to work the next morning at 6am a rock cracked my windshield. I was pissed!!!!Things happen, a rock just came out of no where today and cracked my windshield. The day I am Supposed to get tinted SMH.
Happens to the best of us!Sorry about the rock. Same thing happened to my 2015 Silverado. But it happened the very next morning after I bought it. Bought the truck, got home at 10pm, on my way to work the next morning at 6am a rock cracked my windshield. I was pissed!!!!
But I guess that is what insurance is for.
I have some pretty bad luck with windshields getting cracked in the first week then never happening again for as long as o have the car. I am hoping that is the case here!I had the autostop eliminator on mine. The one that installs behind the screen. It just plugs in and wasn't hard to do. It does look complicated because of taking the dash apart. But it's really not hard to do. Also a perfect time to put a screen protector on the dash cluster. I had mine for 20k miles, no issues worked perfectly.
Sucks about the rock. If it makes you feel any better. I had a large rock come down from an overpass and crack mine on my 1500 when it was still pretty much new. I then had a service truck on a narrow bridge clip my tow mirror with his bed on my HD with in the first two weeks of owning it. New trucks are magnets for crap like that. I've had two windshields get cracked in my life. Both were on new vehicles before the first oil change.
That's interesting, I do a lot of Interstate driving and have picked up my share of rocks in other vehicles. Wondering how many people have done this and how well it works?Yeah it’s unfortunate. Although I did get hit pretty hard by that rock, it came flying across a freeway, I am assuming it’s from a bus.
I like the PPF for the windshield Honestly. It’s usually 200 bucks for a windshield where I am at. (Although some places will gladly charges $500+) And it gives peace of mind.
I’ll probably hold off though if this crack repair does not look good. We will see
Xpel makes a product and few others.That's interesting, I do a lot of Interstate driving and have picked up my share of rocks in other vehicles. Wondering how many people have done this and how well it works?
Thanks,
Rick
I actually did run it through my insurance.Should have just turned it into your insurance. It would have been covered under your comprehensive policy with a small deductible. My deductible for comprehensive is only $100, so i got my whole windshield replaced with a brand new windshield for $100.
My insurance isn't like that. Didn't even try to repair mine. Just flat out replaced the windshield. No questions asked.I actually did run it through my insurance.
With my policy they do a free repair if they can, otherwise they do a whole replacement. Which in this case I might elect now.
I have State Farm Mutual. No problems at all with State Farm.GEICO is like that in FL
