ZR2xBIZON
- Jun 18, 2023
- 2,123
- 6,798
Yepthis picture?View attachment 17954
I would assume (there's that word again). More thoughts and questions...Are the rear lift blocks completely squared, or is there an angle on one surface? That would make them directional...So are they installed in the correct direction?There are a ton of people riding with the Peak lift - I would think my issue would be more widespread if there was driveline angle issues, right?
Peak blocks are square.I would assume (there's that word again). More thoughts and questions...Are the rear lift blocks completely squared, or is there an angle on one surface? That would make them directional...So are they installed in the correct direction?
You'd think this- but I had the exact same issue with a BDS kit in an F150- and BDS sells alot more kits than peak.There are a ton of people riding with the Peak lift - I would think my issue would be more widespread if there was driveline angle issues, right?
I thought someone already said that wasn't your problem?Well, rotating tires and hub rings did not fix it. Has to be the alignment.
Axe thank you hahaI thought someone already said that wasn't your problem?
I'm always here for everyone!Axe thank you haha
