2" lift induced 4WD Wobble issue
Diff drops are pretty much the norm for most lift kits 4 inch or above.
The downside of a diff drop (depending on how far you drop) is you often need to remove part of your LCA crossmember. You also usually have to add a driveshaft spacer to make up the equivalent length increase. Depending on how severe the drop is you may put your axle joints at bad angles too. Very situational dependent.
im not sure if the coil over will alloe you to bottom out completely tbh.
I dont think they have a physical bump stop like day a bilstein 6112. If youre using the dssv maybe a peak suspension collar and spacer would get you where you need.
@Nmass94, this is what I was kind of referring to
Should this be a legit concern for me?
I hope for your sake that solves the issue, however from my knowledge by adding strut top spacers you're only going to make the CVs steeper.
Diff drops have issues, but they do make cv angles less severe.
I think it gets blown out of proportion. It's always a balance between the two.
I think that’s why peak (and some other kits) use a collar to get anything more than a level from the dssvs. Yes a taller spacer would add lift but the rest of the suspension isn’t designed for that much down travel. So instead they raise the spring on the shock body, you loose down travel from ride height but you keep the suspension within its travel range. The same as adjustable collars on aftermarket shocks.
I’m interested to see what pax provides vs their original design.
And I think that a diff drop would help your cv angles but probably throw the rest of the long arm kit’s geometry out of whack.
I measured the spacer and it's around 2.75", I think the new one they are sending is around 2".
Once I have it in hand I will confirm. I might have to do more trimming around the bumper, but TBD.
I'm gonna hold off on the diff drop, only because there seems to be disagreements on the benefits of them. This is still my daily driver and don't want to get too crazy from OEM if I can help it.
Have you received the new spacers and resolved the issue here? I always get a little skeptical when I see large spacers on top of a strut assembly?
I have looked into the PAX builds and have been a little skeptical about the true performance they provide when maintaining the DSSVs. They don't give a lot of specifics on how they lift the front and rear while maintaining the DSSVs and they make sure they don't show those areas when making their videos. I did manage to spy the front spacer in one of their videos but haven't been able to see what they actually changed in the rear.
I did receive the replacement spacers but have not installed them yet.
I have a buddy who owns a shop that will be installing them in the near future while I am out of town.
They look to be about half the size and also slanted/angled. (not sure what that is about tbh).
You are correct to be skeptical, I wouldn't say it's a bad system but I didn't know what to look out for. Seems like you have a better understanding of this. I would call them, they are very helpful and honest. I wouldn't say they are running a smooth operation necessarily but they are trying and they are honest.
I agree with you on that. I do have the same kit from PaxPower. Did you install the spacer and your issue is gone? Can you share a picture of the spacer? Thank you
You are correct to be skeptical, I wouldn't say it's a bad system but I didn't know what to look out for. Seems like you have a better understanding of this. I would call them, they are very helpful and honest. I wouldn't say they are running a smooth operation necessarily but they are trying and they are honest.I
