- Oct 3, 2023
- 113
- 222
- Thread starter
- #21
@Nmass94, this is what I was kind of referring toDiff drops are pretty much the norm for most lift kits 4 inch or above.
The downside of a diff drop (depending on how far you drop) is you often need to remove part of your LCA crossmember. You also usually have to add a driveshaft spacer to make up the equivalent length increase. Depending on how severe the drop is you may put your axle joints at bad angles too. Very situational dependent.
im not sure if the coil over will alloe you to bottom out completely tbh.
I dont think they have a physical bump stop like day a bilstein 6112. If youre using the dssv maybe a peak suspension collar and spacer would get you where you need.
Should this be a legit concern for me?
