- Oct 5, 2023
- 673
- 1,895
I just finished adding the 'upgraded grill lights' from RTGOffroad to my truck, they fit and turned out very well. @Mixander Xi now has 3 different types of lights available, he has the orange marker lights, they look good but I was looking for some extra illumination and not just a marker, these ones are white, or yellow, or both white and yellow at the same time, they strobe if you want and can be mounted in the 3D printed mounts one way or flipped 180 degrees to either have the white on top or the yellow on top. I chose to go with yellow on top and run that during the day, so the white is on the bottom and I run that at night, I was afraid if I turned them over that the white light would be too high and blind oncoming cars, they are fairly bright. When I looked around to compare some of Mixanders products to make sure I was getting a decent deal I found he sell this stuff much cheaper than others, he feels like he should keep his profits low and make up for it with more sales so that these products are available to more people, which is a rare breed indeed! Last he is getting ready to release a set of the upgraded grill lights that add red to the yellow and white set, it won't do red at the same time as the white and yellow but they can strobe the red also if you want them to with the push of the remote control fob button. There is a metal bracket attached to the fob that I didn't want, so I removed it and found the remote sits perfectly in the pen cubby in the console. The lights won't come on automatically, you need to hit the remote button, but I did use the fuse tap to connect to fuse 46 so that when I turn off the truck the lights go off, I just need to get used to turning them on when I start the truck, I am adding it to my startup checklist, start, Sport Mode, Auto Stop off, and turn on the grill lights to yellow during the day and white at night. I really appreciated the 3D printed mounts, they fit tightly in the grill so they will not come out easily, it took some pressure to get them in, but they aren't coming out!
Pics to come!
Pics to come!
