Looks great, spacers? Lift?I have the Mickey Thompson Baja Boss AT 295/70R 18 (24.5”) on mine. Doesn’t even try to rub and looks better. Quieter and better ride as far as I can tell.
What offset are your wheels?So I have the same question that someone mentioned earlier...
I am running 17x8 methods with a tire size of 285/75/17. Zero rub. I have attached a screenshot with a tire size calculator pitting it against a 295/70/18. I want to get a bigger / taller tire without having to do a lift or use spacers. Anyone fit a 315/70/17? lol
Mainly because I do offroad it alot and I am afraid of going bigger with stock suspension, I wont be able to climb without rubbing. Photos and video of recent trips to Anza, CA.
You mention the ride is better as far as you can tell. Curious if the M/T's are a softer E rated tire then the KO2's I went with. I definitely noticed a little more harshness over bumps with the E rated tire vs the C rated stock Goodyears.I have the Mickey Thompson Baja Boss AT 295/70R 18 (24.5”) on mine. Doesn’t even try to rub and looks better. Quieter and better ride as far as I can tell.
WHat offset wheels?So I have the same question that someone mentioned earlier...
If you don’t mind me asking what is the exact wheel and offset you are using? I love this setup.So I have the same question that someone mentioned earlier...
Do you still have these? Do you still recommend them? At this size too? I don’t want any rubbing and I really like the way they look.I have the Mickey Thompson Baja Boss AT 295/70R 18 (24.5”) on mine. Doesn’t even try to rub and looks better. Quieter and better ride as far as I can tell.
Actually I’m on my second set!Do you still have these? Do you still recommend them? At this size too? I don’t want any rubbing and I really like the way they look.
You didn’t have to do any trimming with everything else stock?Actually I’m on my second set!
Just posted on page 3 of this thread on Friday those exact tires. No rubbing issues at all, 285/70/18 Nitto ridge grapplers with fuel blitz wheels +20 offset. Highly suggest them, much better than the stock tires
Love the look of your rig. Did you ever get any feedback on the 315/70/17? I have a zr2 coming in hopefully 2 weeks. I’m looking at two different method wheels that are both 17” and zero offset and 8.5” wide. I don’t want to do a lift and will be getting it off-road on occasion. I’d like to go as big as I can without having trim too much.So I have the same question that someone mentioned earlier...
