🦃 Exclusive Amazon Black Friday Deals 2024 🚨
Don’t miss out on the best deals of the season! 🏴 Shop now 🎁
295/70r/18 will fit stock?
i have a rough country 1.5” leveling kit and nitto recons at 295/70/18 on stock rims. no rubbing whatsoever.
So I have the same question that someone mentioned earlier...
I am running 17x8 methods with a tire size of 285/75/17. Zero rub. I have attached a screenshot with a tire size calculator pitting it against a 295/70/18. I want to get a bigger / taller tire without having to do a lift or use spacers. Anyone fit a 315/70/17? lol
Mainly because I do offroad it alot and I am afraid of going bigger with stock suspension, I wont be able to climb without rubbing. Photos and video of recent trips to Anza, CA.
What offset are your wheels?
I have the Mickey Thompson Baja Boss AT 295/70R 18 (24.5”) on mine. Doesn’t even try to rub and looks better. Quieter and better ride as far as I can tell.
You mention the ride is better as far as you can tell. Curious if the M/T's are a softer E rated tire then the KO2's I went with. I definitely noticed a little more harshness over bumps with the E rated tire vs the C rated stock Goodyears.
WHat offset wheels?
If you don’t mind me asking what is the exact wheel and offset you are using? I love this setup.
Do you still have these? Do you still recommend them? At this size too? I don’t want any rubbing and I really like the way they look.
From my experience they fit without any issues with stock wheels. These trucks don’t have the clearance issues the TB trucks have with the factory mudflap.
Stock wheels, no spacers. They fit.
