Featured
- #61
OkWeekend Warrior! There not made any more. Went BKY year after I bought it in 2008. Warrior Lifestyle makes similar ones but not big.
Ultimately, they are both very capable and will move the load down the roadā¦same frame, same suspension, same cab/bed, hubs, etc. The load rating difference is likely just due to the weight difference of the two motors (Iām assuming here as it all boils down to gross weight vs whether the motor will āpull itā) The difference is really how rapidly it will move the weight, STOP the weight, and how hard the motor works to move the same weight.Axe question....what is your opinion on the Gasser as far as towing?? I live in the south with 95% FLAT roads...so no huge grades etc and are thinking about a 5th wheel around 16,500 LOADED(13K-ish dry) and I LOVE THIS TRUCK....Just not sure for my situation I really need to spend the extra 9500 for the diesel and pricy maintenance cost, not to mention depending on the problem could take MONTHS to get part and install due to "supply chain issues" blah blah blah.....
So what do you think? I've seen countless vids where the gasser max tow for 5th wheel/gooseneck is 18,100 while the diesel is 18,500.......?.......
Ok...and what if you weren't pulling that often?? And you had no use of high idle because you don't idle your truck that much to need that function?? Would you consider the new HD gasser then?(also living and traveling in Flat land areas but not towing that amount of weight that often throughout the year)Ultimately, they are both very capable and will move the load down the roadā¦same frame, same suspension, same cab/bed, hubs, etc. The load rating difference is likely just due to the weight difference of the two motors (Iām assuming here as it all boils down to gross weight vs whether the motor will āpull itā) The difference is really how rapidly it will move the weight, STOP the weight, and how hard the motor works to move the same weight.
Watch some videos of what ol 1990 Ford Rangers pull in various countries around the worldā¦man hasnāt yet reached the GVWR for a 1990 Ford Ranger four banger with a five speedā¦maybe some day man kind will find it! Point is, not much can get a lot rollingā¦safety isnāt tied to the motor.
If I were pulling all that often (which I do) regardless of where I livedā¦I would own diesel trucks (which I do). Mainly because they just tow āeasierāā¦BUT in full transparency it comes at a cost up front, at the pump, fuel treatment, and increased oil change and fuel filters. I get quite a bit of that back in resale and thatās how I justify it. The emissions aspect is starting to turn many of guys in my area towards the new wave of HD gas motorsā¦just too many things nowadays stacked against the oil burners unless you just simply āwant oneā
my next HD, will be a diesel as equipment, cattle, and hay are heavy and I just like the torque on tap, but it will also have the high idle switch as I idle a lot around the farm and want to help alleviate at least some of the emission issues via high idle.
Hope that helps
100%, itās completely capable - and itās lower cost of entry, lower cost to drive every dayā¦and y donāt need to high idle a gasser. It may work a bit harder when you do pull (keep in mind itās what they are made for) but given itās not that often, I see it as being the ideal solution for your use case.Ok...and what if you weren't pulling that often?? And you had no use of high idle because you don't idle your truck that much to need that function?? Would you consider the new HD gasser then?(also living and traveling in Flat land areas but not towing that amount of weight that often throughout the year)
Lol!...10-4100%, itās completely capable - and itās lower cost of entry, lower cost to drive every dayā¦and y donāt need to high idle a gasser. It may work a bit harder when you do pull (keep in mind itās what they are made for) but given itās not that often, I see it as being the ideal solution for your use case.
Hook it up and give it hell!
Only two things you're going to be missing. One is the torque of the diesel to get loads moving in a gasser. Your gonna run much higher rpms getting that much weight moving. The second thing you're giving up is engine braking to stop heavy loads that you get with a diesel. My two favorite things about the diesel is high torque/low rpms and engine braking makes it much easier to tow.Ok...and what if you weren't pulling that often?? And you had no use of high idle because you don't idle your truck that much to need that function?? Would you consider the new HD gasser then?(also living and traveling in Flat land areas but not towing that amount of weight that often throughout the year)
#THIS is my position as well!I went with gas because of emissions and money. The emissions systems suck on diesels. Deleting them is getting harder and more expensive. I also think you really have to tow a lot to be worthwhile. 3 gallon oil changes, 50 dollar fuel filters. DEF if not deleted. All that and they don't really get great mileage. My last duramax averaged 14-15. Sure I could get 21-22mpg on the highway. But i typically averaged 15mpg with mixed driving. With the cost of diesel fuel, a little better mileage isn't saving anything at the pump.
They tow better and personally I love the sound of a tuned straight piped Diesel. But you really do have to tow with them often or heavy. for them to be worth it.
This is the direction I am headed as well for the same reasons and my short distance driving.#THIS is my position as well!
Yup.....if I was towing a lot....a d up steep grades all the time...traveling thousands of miles towing throughout the year...I too would get a diesel..but as I tried to explain...MY situation is different....Minimum towing...flat lands and not moving that much throughout the year...Same here. I would have gone with diesel if it was a pre 2007 version meaning no A/T. Actually the pre 04 didnāt even have a cat.
With all the SCR/DEF and DPF issues and not towing much gas is the best option.
I don't think the DEF/DPF emissions systems are that unreliable on modern diesels. Sure it's the one item you hear the most about and I've experienced 3 minor issues with my last Duramax in 9.5 years of running it.
1) DEF temp sensor, 2) 9th injector, 3) egt sensor (that's also on every truck).
Total down time was 4.5 days, with the DEF temp sensor taking 2.5 days. Only cost was $367 for the diagnosis and repair of EGT sensor last week. Only other thing I've replaced at my expense is lower ball joints due to cracked boots and thermostats. That truck is a loaded LTZ that lays down more power than the current 24 offering. My boy is still driving that rig today and I expect to have normal maintenance for some time to come. It was 70% daily driver in traffic, 25% towing recreational gear, 5% idling for warm ups, traffic, etc. I've short tripped many times and shut down during regen several times. Start up again and keep rolling with no real concerns. Truck only cost me $56k. Overall very reliable and inexpensive truck for me.
Contrast that with my new ZR2 and I've just logged my second electrical problem this morning in 6 weeks and less than 800 miles. First trip to dealer did not resolve issue and now I need a second trip for two issues. I will have already logged 3+ days at the dealer by 2 month mark.
If your sitting around thinking your gonna avoid problems with a gasser, but neglecting to remember that these trucks share notable electronic problems that are 3 years running, you don't understand what's happening in the current market. These trucks may be the least reliable truck you'll have owned, gas or diesel. That's just how it is for $75-95k. Get to know your dealer and have a chase truck available for downtime.
One of the 2500 Rams we had was a 2011 and nearly 0 problems, I think it had a tierod recall. Had 2014 3500 dually Laramie Longhorn, that was the sweetest rig I've ever been in. Sold it after my Dad got rid of his 5er. Still have a 2018 2500. No real issues with any of them. They worked hard, but didn't pile on the miles.I have a 2011 3500 Ram. It eats O2 sensors. Replaced both sensor at least three times.
I work in the diesel industry and if you dont load them they tend to have issues. Glad to see you have good luck otherwise.
I have a Chase truck for downtime, however just BECAUSE I have one doesn't mean I can tolerate the downtime. If I were at home and worked around the house...sure...but contracting out on the road...I don't have time for 4.5 days...2.5 days etc downtime...or from my coworkers with multiple different diesels ranging from 2005 model Ford this and chevy that to current newer models having the problems they have and downtime because such and such part isn't availability or the dealer or other maintenance shops that have WEEKS of waiting time to even get seen about the problem....I don't think the DEF/DPF emissions systems are that unreliable on modern diesels. Sure it's the one item you hear the most about and I've experienced 3 minor issues with my last Duramax in 9.5 years of running it.
Unfortunately, if you can't afford downtime, you might need three trucks, not two. If you've bought anything in the last few years it's part of your initiation fee.I have a Chase truck for downtime, however just BECAUSE I have one doesn't mean I can tolerate the downtime. If I were at home and worked around the house...sure...but contracting out on the road...I don't have time for 4.5 days...2.5 days etc downtime...or from my coworkers with multiple different diesels ranging from 2005 model Ford this and chevy that to current newer models having the problems they have and downtime because such and such part isn't availability or the dealer or other maintenance shops that have WEEKS of waiting time to even get seen about the problem....
I understand your "both gasser and diesel will have problems, especially electronics sharing the same system" etc etc....but again I have multiple coworkers from all over the country on these projects I go on and I get MANY REAL WORLD situations and opinions from their Experience with diesel vs gas and I can tell you....so far for years now....the gasser generally has less problems and less downtime.....
Do some gasser have more downtime than diesels??....SURE...but again from my analysis of both from multiple guys experiencing...the gasser seems to have less downtime/problems... and again it all depends on YOUR specific needs and situation....I DO love the diesels power and sound thou
Yea...thats true tooUnfortunately, if you can't afford downtime, you might need three trucks, not two. If you've bought anything in the last few years it's part of your initiation fee.
I've never seen so many posts about electronic problems and bad parts on trucks since my first time on a ZR2 truck forum in 1998 when I was using a dial up modem.
The post covid world runs off mediocrity and you have to accept it and pay up. You don't have to like it or admit it, but things are a mess. These poor quality truck parts and electronics are just one example.
Hopefully it's less issues going forward, but with each new member on this forum it seems they often lead in with problems.
What octane are you using?Oh I understand. That's part of why I posted that specific video. That's one of his complaints. There is no 3500 option in the ZR2 or AT4X line up. There really should be just for the legal aspect. 3500 SRW option would help a bunch. Or even just a max trailering option on the 2500s.
I purchased the Gas ZR2 HD, but I really wasn't concerned with the ratings. The half ton did what I asked it to. But I'm pretty sure I had it overloaded several times. Shouldn't be an issue for the HD. But if I were in your shoes, I doubt I'd went that route.
On the plus side it really is just the legal aspect. Mechanically it's no big deal. You aren't going to bend the frame, bend an axle or burn up the transmission, ect. You will probably need airbags because of the softer suspension. I would check the tires rating. That's one area you definitely don't want to push limits on. But the rest is is pretty much the same across all the trims in the HD lineup.
