- Oct 3, 2022
- 1,323
- 3,352
Featured
- #81
I just run 87 in the 6.6. The owners manual says regular 87. Compression ratio on it is like 10.8. The 6.2 is 11.5 which is why it calls for a min of 91 octane. That said towing in the summer I plan to use 89. You add some extra heat and a load, 89 probably isn't a bad idea. But I think in the winter and just running around with out a load. Running Higher octane would be pointless.What octane are you using?
That was actually something I took into consideration moving to the HD. I knew the mileage would be worse, But 87 is almost a dollar cheaper per gallon here. I did the math, if I only average 12mpg using 87, it's actually a few dollars cheaper then getting 15mpg with premium in the 6.2, lol. That is sort of the same deal with Diesel. It cost more per gallon. So it typically isn't much cheaper because a Duramax is probably going to only average a few more MPG. You factor in DEF, Filters, ect. You really have to get much better fuel mileage for it to save anything at the pump. If you tow a good amount that's really when diesels start to shine. They will usually get much better mileage while towing than gas. My duramax before only averaged around 15mpg over a tank of mixed driving. So when I went from it to a 6.2 that called for premium. My fuel cost was actually less on the 6.2 than it was on the Duramax. Diesel around here has been higher than Premium for a while now.
