- Mar 11, 2023
- 2,126
- 3,931
100%Just burns my brain your sons and you had to deal with Karen and the cronies. Doush bags seem to have all the rights now.![]()
Yep...thanks Brandon!Just burns my brain your sons and you had to deal with Karen and the cronies. Doush bags seem to have all the rights now.![]()
Everything you thought you could trust has been failing for a while now. It's been in overdrive the last 4 or 5 years. It's every man for himself. Good luck!Just burns my brain your sons and you had to deal with Karen and the cronies. Doush bags seem to have all the rights now.![]()
I see we do have common ground! I fear there is only one way to get us back on course….if the will is thereEverything you thought you could trust has been failing for a while now. It's been in overdrive the last 4 or 5 years. It's every man for himself. Good luck!
Update:Added Bora 1.25” spacers today. Cutting the wheel studs was tedious but the end result was worth it.
Check out my trimming thread, if you cut a portion of the plastic molding on the rear of the wheel well you should be able to eliminate rubbing. I did mine 10k miles ago and it functions fine and you can hardly tell it was trimmed.Update:
I finally got my truck aligned.
After alignment, I do have rubbing on the back side of the front wheel wells while in reverse, wheels turned.
3/4” Peak spacers, Dirt King upper control arms, and 1.25” Bora wheel spacers.
I have stock wheels and tires
I have read yours and others posts thoroughly. My trimming appears to be minimal at the time.Check out my trimming thread, if you cut a portion of the plastic molding on the rear of the wheel well you should be able to eliminate rubbing. I did mine 10k miles ago and it functions fine and you can hardly tell it was trimmed.
Looks good. Im looking all around then the Chevy logo pops out. I think you right a ZR2 probably look cooler. Where there wires already there? What did you tap into?So added the custom puddle lights. Would be nice if they had a ZR2 badge....
Just replace the puddle lightsLooks good. Im looking all around then the Chevy logo pops out. I think you right a ZR2 probably look cooler. Where there wires already there? What did you tap into?![]()
Quick question...I was looking at the Airaid Jr kit and they also have a closed box intake for $50 more. Wat are your thoughts? Pros vs cons? Thanks!It's all in your head my friend. It's just your brain trying to justify the expense. The K&N is actually the worst intake one could buy. It is not a closed box and is more of a HOT AIR INTAKE than anything. If anyone is going to buy one, it's for the looks, noise it may make and nothing more. @JGaray If you're hell bent on a CAI, then be sure to get a sealed box unit like a Volant, S&B, etc. Anything but the K&N or any other open box intake.
This mod has zero impact on mileage or HP gains. If you want HP gains, you'll need a tune plus more.
@JGaray - the OEM airbox is actually an EXCELLENT airbox as, many have shared on this forum. What I did, along with several others, is buy an Airaid Jr. Kit that keeps the stock MAF in place, attaches to the OEM box and replaces the air pipe. It gets that big UGLY rectangular box out of the engine bay and smooths out the air flow a bit. I did mine for looks and nothing more. Then drop a great quality DRY filter in (no oiled filter) and call it a day.
2023 Chevrolet Silverado 1500 6.2L V8 Gas Performance Parts | AEM
Shop K&N product that is compatible with the 2023 Chevrolet Silverado 1500 6.2L V8 Gas.www.aemintakes.com
That’s the kit I installed a year ago and made the forum group aware of it. Great product!Quick question...I was looking at the Airaid Jr kit and they also have a closed box intake for $50 more. Wat are your thoughts? Pros vs cons? Thanks!
They are OEM replacements from the dealership. You just pop the old ones out slide the wires off and pop the new ones back in. Literally less than 5 minutes. Here's the part number.Looks good. Im looking all around then the Chevy logo pops out. I think you right a ZR2 probably look cooler. Where there wires already there? What did you tap into?![]()
The closed box or the Jr kit? I saw your info on the Jr kit and was checking it out when I saw that they also made a closed box full CAI kit. I was interested on if the $50 difference is worth going full CAI or stick with the Jr kit. BTW, thanks for all the info you guys provide on this forum, I've lived on here for over a week since I got my truck, haha!!That’s the kit I installed a year ago and made the forum group aware of it. Great product!
You don’t need to change out the air box. The OEM air box is quite nice. I put an AEM dry filter in it and just installed the charge pipe and fittings. All plug and play and cleans up the engine bay quite nicely. By using the Jr. kit, the MAF sensor remains in the factory position which is most ideal.The closed box or the Jr kit? I saw your info on the Jr kit and was checking it out when I saw that they also made a closed box full CAI kit. I was interested on if the $50 difference is worth going full CAI or stick with the Jr kit. BTW, thanks for all the info you guys provide on this forum, I've lived on here for over a week since I got my truck, haha!!
I have the OEM sliders in my garage. Took them off at 500 miles. It's just a short jaunt across the country to pick them up.Think I've lined up a guy to fab me rock sliders finally- in June however.
Got it, that makes great sense. As I was searching air intake info I saw that K&N owns AiraidYou don’t need to change out the air box. The OEM air box is quite nice. I put an AEM dry filter in it and just installed the charge pipe and fittings. All plug and play and cleans up the engine bay quite nicely. By using the Jr. kit, the MAF sensor remains in the factory position which is most ideal.
