Thanks. I may try it with it on and just see how it goes. Would rather not have to pull it off and put it back on. Just increases the risk of bending pins etc each time Id do it.It probably wasn't necessary to remove it, but if I was having any programming done I would just to be safe. it's not going to hurt the Range because it's post ECM, but if there were any problems they may blame it.
I think it's pretty low risk install. The pins are robust and seating the module is smooth. Good seals and locking mechanism.This is what I posted on earlier...when someone Fs up the pins on their ecm...then its on....We need to get together as a group and tell Range we need answers not
...and gm and their engine killing BS...there ya go AXE...I have a Range Module ordered...NOT SKEERED... But its time to quit experimenting on our trucks and get facts not BS questions.
So you said previously stated you didn't think your ZR2 ran smoothly before the range module, perhaps there's another issue to be resolved.My economy is running .1 mpg better after a month. not much, but better is better.
Did you send in an oil sample? Only way to know if your getting excessive were until it pukes out hard bits.Be that as it may the GM 1500 is rated one of the most reliable last year by JD Power.
I only have 6k on my 6.2 now and I haven't had one issue with it so far with the vehicle. I changed my oil the 2nd time yesterday and I cut the filter open, it was perfectly clean . so there's no way to know what will happen from here on, but I can say it didn't leave the factory with any bearings out of spec or a defective lifter that would be showing by now.
For you to even say you got a 0.1 mpg increase is laughableI didn't expect my fuel economy to improve, I actually expected the opposite. so even a .1 improvement is a win to me. I have it set on the 450 mile interval so we'll see what happens next.
I have build dozens of flat tappet performance engines and I've seen enough cam failures to know how to read filter media. sure it's not precise as an analysis but if you even have a minor problem you can see it. it's had enough run time to know there's nothing serious wrong out of the box is all I'm saying. down the road anything is possible.
Well duh. I'm saying my average when set on the 450 mile setting is .1 better than it normally ran prior to the installation. what part of " average " is statically precise for each individual event ? average economy is the best we can do and it's .1 mpg better.For you to even say you got a 0.1 mpg increase is laughableThere are SOOOO many parameters and variables that change on every drive you take, it's impossible to say you got 0.1. We all know that no two drives or five drives are identical in every way.
I'm mostly doing g samples for my own curiosity. I thinkmif I ever have a problem, it'll be interesting to see the progression in the oil analysis. If it's simply a early catastrophic failures, then the analysis won't mean much, other than knowing it wasn't a typical wearing out problem.I didn't expect my fuel economy to improve, I actually expected the opposite. so even a .1 improvement is a win to me. I have it set on the 450 mile interval so we'll see what happens next.
You continue to be an @$$. Enjoy your 0.1mpg increaseWell duh. I'm saying my average when set on the 450 mile setting is .1 better than it normally ran prior to the installation. what part of " average " is statically precise for each individual event ? average economy is the best we can do and it's .1 mpg better.
I can draw pictures if you send me your crayons maybe that will explain it better.
You continue to be an @$$. Enjoy your 0.1mpg increase![]()
Must be the AmsoilYou continue to be an @$$. Enjoy your 0.1mpg increase![]()
You are the asshole, I said over the last 450 miles my mpg was up .1 and you had to belittle it. considering it is commonly accepted that the DFM increases fuel economy an increase of any kind or even no change when disabled is noteworthy.You continue to be an @$$. Enjoy your 0.1mpg increase![]()
It's not the Range unit...it's the Amsoil you're usingYou are the asshole, I said over the last 450 miles my mpg was up .1 and you had to belittle it. considering it is commonly accepted that the DFM increases fuel economy an increase of any kind or even no change when disabled is noteworthy.
I don't give a FF what you think of it but others may find it interesting. if people continue to find increases it can be said the Range actually increases MPG . unless you spend a lot of time licking windows that's an interesting discovery no matter how minimal it is.
