Yes, if you think it'll benefit you. No, if you think there are no benefits.So are we recommending the DFM disabled or no?
I'm no expert, but I don't see a downside.So are we recommending the DFM disabled or no?
The two I have both run great the way they are from the factory. I bought one anyway, so I could tell the truth about the performance without the bias.The best way to look at it is, do I have $229 to spare for better performance, smoother operation and reduced chances for lifter failure? if you don't them better pass.
The point of DFM is to save fuel by switching the engine to a more efficient mode of operation at light load. It takes the same amount of power to move you down the road at 60mph whether it’s running on 4 or 6 or 8 cylinders. When DFM is active the engine has the throttle valve open more than it would running on 8 cylinders which reduces pumping loss while the engine is in that mode. Reducing parasitic drag by controlling oil pump output is part of reducing losses on the engine. The oil pressure really isn’t a concern with these engines as they all have high volume oil pumps. That pump moves a lot of oil around in a hurry.ChrisTX, ignore some of these dipchits, you sound like you're more onto this than anyone so far. anyone that thinks you need to spend time on a forum to know anything obviously doesn't know anything. so why does the oil pump control cut pressure in the deactivation then? another energy saving measure? do you agree stopping the deactivation should reduce lifter failure?
So I drove 280 miles today on a rural eastern OR highway with little traffic, lots of corners and lots of hills. there is a definite better throttle response, less downshifting , better compression holdback on hill descent, sounds better and I notice no symptoms of valve deactivation at any time. maybe there is, if so it's nothing worth mentioning.
None of this surprises me, what does surprise me is my fuel economy is 2/10 MPG better than it's ever been on the same trip. I'll have to see this play out over time before I'm going to say it helps the MPG, but I'm comfortable saying it's not going to make it noticeably lower.
What if I agree with you in my unbiased review?I hope you didn't spend $229 just to tell us the truth. that old saying a penny for your thoughts, would be overvalued.
I am impressed with the product, and I'd buy it again. I'm not compensated by Holley in any way so I'm not sure why I'd be biased. so, take it for what it's worth I don't care either way.
I emailed Range about battery drain, no response.So the DFM delete doesn't seem to be the battery culprit...Not sure what was...
But it needed a new battery..
After a couple hundred more miles on a new Battery all seems good.. I love the smoothness of the engine! Oh my milage today was 20.3 in 71 miles travel. Outside temp around 60 deg. so I have to say I'm liking that!
You had battery drain also?I emailed Range about battery drain, no response.
No, I'm still in the truck order process. But was curious about the battery drain issue, so I thought I would go to the source. Maybe the Range module is not the assignable cause.You had battery drain also?
Gotcha.No, I'm still in the truck order process. But was curious about the battery drain issue, so I thought I would go to the source. Maybe the Range module is not the assignable cause.
I'll sell you mine for $500 guaranteed Wednesday delivery.Mine finally shipped. They sure arent shipping anywhere fast. It was late shipping out to begin with and says it wont be here til Thursday of next week. Ive had stuff from California make it here through the USPS faster than that lol.
