Low Oil & Check Headlight indicator
Just before the last two oil changes my low oil light came on forcing me to add a quart. The last time was maybe 2 days before my scheduled oil change so I wasn't all that worried. This time I have 20% to go for my next change. I added a quart. Couple days later I park in my driveway with my front end forward on about a 15 degree slope. Fire it up to take my wife to work and check engine light was on all the way there and back. Did it again when I parked similar. This morning I Check the dipstick and oil is low so I added another quart to get it to halfway on the mark after I ran an errand, vehicle was on the flat level surface overnight and through the trip. It's going in on the 12th already for the hood issue where the scoop is rubbing and etching the corners of the finish. 2022 6.2 L Almost 33,000 miles on it. While they have it they are going to service it, perform 3 recalls (Trailer brake, daytime lights etc). Also with a problem I have with the left front headlight, when it rains a few hours later I flip the turn signal on and it flashes quick and message Check Headlight message pops up. Dealership has not been able to recreate that issue. I was going to yank the headlight and look it over for cracks or broken seals in the headlamp assy before its out of warranty.
Almost a 6 months back I remember talking to another owner of the similar truck that was frustrated with the dealer could not figure out why his was burning oil. Just a few days ago I talked with a guy that had a 2024 with a couple hundred miles that had the oil pump go down on it. I was wanting to see if anyone has heard of similar for both the oil and headlight issue and what the resolutions were. I'm so close to the 36K warranty that I want to figure it out before it goes out of warranty.
If you’re waiting for the oil life gauge for your oil changes, then it’s common to burn a little oil. I say little, like a quart possibly more. I do oil changes every 5,000 miles, regardless of the oil life remaining. I also check my oil level randomly between oil changes. You need to pop the hood every once in awhile, check fluid levels and conditions under the hood for preventative maintenance.
As for the headlight issue, I hate when dealerships say they can’t replicate the problem. Sounds like your assumption that there is water entering the assembly is spot on.
Sorry about the issues you're having. I agree that you've probably got water intrusion into your headlight assembly. But I have to say, when I saw the title, all i could think was your blinker fluid was low... 🤣🤣
I've determined mine uses about 1/2 quart per 3k thousand miles. At one time I thought it was 1 quart, but I've captured the oil at the drain and measured it to be sure. Also, my dipstick doesn't read right or consistently. I park right next to my wife's 6.2L Tahoe and hers is spot on, but mine never seems to look full right after a change.
Service Advisor I've known for 27 years said that the new 6.2L motors would be in spec at 1 quart per 2 k miles. It used to be 1 quart per 3k.
If I was you, I'd change my oil earlier and don't worry about adding. If your doing 6-7k intervals following the DIC, I'd assume adding 2 quarts might be right.
I drive mine harder than some, so I expect a little blow by to be normal. If my wife drove it, probably be the same as her rig.
So the dealership thinks the headlight and check engine light is because the onstar module is out on it. Friend in the body shop took care of the hood service bulletin and wheeled it over to service where they could only do an oil change. They did not do the decal flash for the trailer brake, daytime lamps etc because they had one vehicle with the o star out and would not accept a successful flash and vehicle would not start. No ETA for the part and 2,000 miles left on the warranty now. They said come back before out of warranty so they could open a ticket.
Looking on GM forums and seems like several others in the same boat. 6 plus months with gps, maps, onstar not working with check engine lights etc. lots of them out of their warranty period.
