SheeeshI assume those side lugs in the shape of an S are for stronghold or snow? They should have used an H for hideous!
I challenge your theory. Only way to settle this like the Gentalmen we aren't is to buy one and cut it open.Not sure how much Internet sleuthing was done here, so I'll offer this to the guy that has me blocked cause he already knew more than me about tires.......LOL.
The 295s are load range E rated for 4080 lbs. The 35s are load range F, with 3640 lb load rating. That could imply 10-12 ply rating which typically means heavy sidewall plys. I can guarantee they are 3 ply or they wouldn't have those ratings......simple!
Cooper Discoverer® Stronghold™ AT Tire | Cooper Tire
Explore the Cooper Discoverer® Stronghold™ AT tire from Cooper Tire. Visit us to find a Cooper Tire retailer near you to schedule a tire installation appointment.www.coopertire.com
WOW this guy is actually an idiot. Will not take him off ignore again. Rather than just admitting he is wrong he just digs himself deeper. Pretty sad actually. Know he will come back again and use more bad language, but I will not see it. You folks have fun with this fool however, look up the information cited, as he is dead wrong. Casting aspersions does not make you right.I lnew you couldn't stand not to unblock me because you appreciate good information.......LOL. You should block me again tho cause you're full of shit.
I can walk right out and look at my Load range E and above tires. They all have a stamped 3 ply or above sidewall rating.if they are rated above 3500 lbs.
You can't put a heavy truck into service and then load it down with another 8-16k without having stiffer sidewalls. That's how they get the tow rating and how they can roll down the road 25k gross.
Besides that, nobody looking for a good tire ever rolled on a Goodyear. If you want a premium tire you have to run Toyos. That guy you talked to on the phone secretly runs Toyos on his rigs.
You probably follow me on X too for other good info..........nobody ignores the good accounts, cause its too much fun.........you've established that.......LOL.WOW this guy is actually an idiot. Will not take him off ignore again. Rather than just admitting he is wrong he just digs himself deeper. Pretty sad actually. Know he will come back again and use more bad language, but I will not see it. You folks have fun with this fool however, look up the information cited, as he is dead wrong. Casting aspersions does not make you right.
Lol didn't I mention how much I liked the Coopers? Been traveling the last month, AZ, NM, CO. I know the tread is minimum 10 ply. Not sure on the sidewall. Better than GY. Had a GY blow out on my '20 and took the bed side with it.Not sure how much Internet sleuthing was done here, so I'll offer this to the guy that has me blocked cause he already knew more than me about tires.......LOL.
What's your name on Twitter? I'm always up for a good followYou probably follow me on X too for other good info..........nobody ignores the good accounts, cause its too much fun.........you've established that.......LOL.
