GM can't build 6.2's fast enough to meet demand for new and broken ones
If Trump would get rid of the EPA and do away with the stupid CAFÈ then maybe the manufacturers could build a motor that would last. We did not have these issues until auto start stop and cylinder deactivation came to be.
My thing is, other manufacturers have the same thing. You hear it at stop lights. Everyone’s vehicle turning back on, all these other car company’s having the same issues?
As much as I want to buy into the disable DFM and problems are solved I cannot.
The reality is GM buys batches of lifters in the hundreds of thousands so a “bad run” will screw up tens of thousands of units.
*Knock on wood here*
I drove an AFM 5.3 with religious oil change intervals for 150k and this 6.2 for 25k thus far. Not a tick let alone side of the road.
Some of it is luck of the draw but let’s be real here. Turning off DFM will not save you if the spring breaks inside the lifter and it collapses. That’s a QC issue from the supplier.
As a professional engineer and custom motor builder your way off the mark.. No pun intended
And not trying to disrespect your opinion ,but it is just an opinion. Some of your statements are facts. And the rest speculative. Dynamic Fuel Management is a novel idea based on regulatory mandate. All manufacturers are struggling with ideas. It just so happens that the current set of dynamic are all known.
This forum is to general for me to explain to you all the variables. So I'm gonna say GM know and is willing to allow said device development to shut off some or all of the variables. They clearly know the savings.
To conclude Range DFM delete is a positive step in saving them money.
I get that most don't understand why .
Any time a system tries to control oil pressure to regulate efficiency is looking for connective failures! Simply put that's why shit happens!
I think both are correct statements given the proper context. AFM/DFM is subject to both short term and long term effects related to design and maintenence. As Wutang stated, I've run two high mileage AFM motors with excellent maintenence and never a problem. Most issues were caused by uneven wear on the cam due to the four cam/lifters that were not shut off during deactivation. DFM is a new design rotating amongst all cylinders and subject to failure from incorrect machining, improper oiling, and bad lifters.
So it's unlikely you'd see catastrophic failure in the AFM systems, but long term wear issues, which better maintainece practices can increase life. DFM has a lot more variables and is generally caused by catastrophic failure so they go to hell much quicker. Even with better maintainece and the DFM module, it may not be enough to prevent failure if the parts are bad.
As luck would have it, Dave's Auto just did an autopsy on a 6.2L motor with four miles on it!
I guess GM didn't want it back cause they already have thousands sitting there......saves on return shipping.....LMFAO.
Actually, I think it's a failed reman hence the reason it's a 23 with 4 miles, the pistons look used, and there's a heat tab on the block which is used for reman motors. There are comments like that on the video.
So I've been entertaining purchasing a ZR2 but am hesitating pulling the trigger after reading these adventures. I'm a mechanical engineering and very curious about the cycle and sequence of events with this DFM. I'm fastidious about maintenance but if failure is a foregone conclusion down to not if but when then I'm happy to wait to see if this gets sorted out later in 25' or 26'. With the DFM range unit can you elaborate on the circuit? I.e. if it keeps all cylinders running is there any time when the oil pump shuts down or reduces oil pressure to catastrophic levels? Thanks in advance.....B
Yes I can elaborate just a little
1st yes oil pressure is no longer regulated with the Delete
2nd all lifters are regulated full pressure , zero collapse!
3rd motor Valcum is now stable , reducing none paracidic drag on rods and crankshaft
This process is the most important aspect to the delete process! And without delete this is were all things go south. Bearing failer and fatigue.
4th Fuel management is still active and on some models it can and will equate to zero combustion pressure at low rpm. Hence no power..! This doesn't effect the throttle demand or acceleration!
Hope this helps!
Remember oil change cycles should be between 3 and 5k miles for optimum life on
Low Paracidic drag oil "0w-20w"
The redesign lifter will benefit from the oil control issue and in my opinion is not the current problem.
Past issues of the lifter was manufacturing flaws , material flaws ECT..
Not a current issue!
