If there is, I have not discovered it yet. I can feel when it’s active through the steering wheel (slight vibration). I have been driving in L9 or L8 since the first 400 miles, after I discovered that doing so disables the DFM altogether.Hi all,
Is there some indicator on the dash that turns on/off when DFM is activated/deactivated while driving?
THX
B
That only disables the auto start stop. You need the Range Module to stop the DFM from engaging.WHAT ABOUT THE START/STOP BUTTON? Doesn't that turn off the system? I always disable it (turn it off) when I start the engine.
My Jeep has an indicator on the dash when the engine switches to 4 cylinder mode, was wondering on the truck.If there is, I have not discovered it yet. I can feel when it’s active through the steering wheel (slight vibration). I have been driving in L9 or L8 since the first 400 miles, after I discovered that doing so disables the DFM altogether.
My 2017 model with the L86 engine and AFM had an indicator on the dash, but I think GM deleted that with the L87 engine.
The L86 engine could disable 4 cylinders, but the L87 engine can disable up to 7 cylinders (as I understand).
It used to indicate V4 mode when the trucks had AFM, but not with DFM. Just listen for the sound difference in the motor or exhaust.My Jeep has an indicator on the dash when the engine switches to 4 cylinder mode, was wondering on the truck.
NoHi all,
THX
B
Can you provide more details?
NoCan you provide more details?
Coming in hot with the double no
This is how I solved the issue of knowing when a regen cycle is running…Hi all,
THX
B
I use my Banks gauge
I use my nose and watch the fuel mileage drop.I use my Banks gauge
I have been through several regens now and have failed to see a fuel mileage drop during my regen. Maybe if I got my nose out of my @$$, I might have smelled something tooI use my nose and watch the fuel mileage drop.
I tracked hundreds of them on my last rig over 10 years and when I was done, I wondered why the hell did I track hundreds of these over 10 years to prove it worked just fine time and again.
The emissions system is now the most reliable parts in these trucks....... go figure!
If your nose was in your ass, I'm sure you smelled something.I have been through several regens now and have failed to see a fuel mileage drop during my regen. Maybe if I got my nose out of my @$$, I might have smelled something too![]()
If your nose was in your ass, I'm sure you smelled something.![]()
That's cause they get horrible mileage so it won't drop much. It's easier to see in older vehicles.I have been through several regens now and have failed to see a fuel mileage drop during my regen. Maybe if I got my nose out of my @$$, I might have smelled something too![]()
