2" lift induced 4WD Wobble issue
Spoolin
Active member
Minnesota
Hey All,
For you suspension guru's out here... I have a 2" lift on my ZR2.
Wasn't until the temps drops and the lakes froze over and started using AWD and 4Hi mode that I noticed that the front end of the truck wobbles pretty seriously when the front end is unloaded (hard acceleration or towing/hauling heavy loads).
Called a local suspension shop and they said it's a "known GM issue" and to just not use Auto mode.
Feels a lot like the knobby tires are hitting the firewall and everything starts to vibrate / wobble, increasing with intensity the more the front end unloads.
Any thoughts on what to look into? Truck also has extended axles which I wonder if that has something to do with it.
I’m not a guru, but I do have a few questions: First being is this a 1500? What suspension lift was used? Does it have strut spacers, collars, or something else? Why extended axles? More extended than factory trailers boss/zr2?
I have a 2" lift over stock and have no wobles. It's a peak kit. Nothing on 4hi or 4lo. Everything else on the truck is stock and I removed the sway-bar
It is a known issue with certain Lifts. ReadyLift has the following on their kit "NOTES: Use of Auto 4 Hi feature not recommended. "
I also know that Peak Suspension says this is not an issue with their lift. I've had no issues with either of my ZR2s that have the Peak 2.25" lift.
Hey, it is a 1500 ZR2.
Lift is Mazzulla Control arms and axles.
Axles were to fit 35's and to fit inside the flare kit.
I was told that as well. Some of these companies have in small print "not to engage AWD or 4WD", something I wish I would have known prior to doing this.
At speed or when the truck is level it is not an issue, but when under hard acceleration or increased suspension travel it is rather worrisome, enough so that I will probably have to remove the kit.
Maybe the axles are going bad since you said it had been fine until more recently. Maybe some splines are stripped and when the suspension extends the splines arent making full contact. May want to pull them and see what you find.
I have an appointment with a shop in a couple weeks to get the truck on the lift. I would hope the extended axles are/were designed with that in mind but it's a fair assessment of what could be happening.
I'll try to take some video's of it tomorrow just to help paint a better picture.
