Similar to TexAgg2002, I just added the 1.5” Dynofit aluminum spacers. I did not like the tucked in stock look, wanted to do 1.25", but couldn't find that in a brand I felt comfortable with. Glad I went with the 1.5", definitely gives the look it should have from the factory in my opinion. I went with the spacer option as a stop gap, didn't want to spend 3-4K on new wheels and tires. Spent $120 on the spacers and $35 to install. Figured I would wear the stock tires out and then determine if I want to spend the money on new rims and tires. Honestly, I am liking the look, and at this point don't think I will change anything.
I did notice there is a slight change to the drive, on the highway feels about the same, maybe a little vibration thru the steering wheel, on the rougher roads little bit more vibration. Nothing significant though, I did notice rubbing when I was backing up, so I will need to investigate more. Tad more road noise believe it on not with the tires pushed out a bit, again nothing significant.
