Under Seat Tray w/Kicker Sub
The_Q
After installing the Kicker subwoofer, I felt something was missing where the Jack mounts. The sub requires the removal of the under seat storage bin. Not liking the sight or the Jack sitting there, I cut the removed bin to fit. I’m a lot more satisfied with how things look now.
Stupid question but where exactly does the sub sit in that picture? Also, do you think the sub was worth it? I plan to get it, and also ordered the truck with the rear under the seat storage, so I was trying to figure out what I would do.
The sub is in the large portion in the middle of the large plastic piece. It's a downward facing sub.
Is that plastic cover pretty stout? If I put my GSD in the back and he were to sit or step on it, would it be something that would crack easily do you think?
@GearheadSS answered the first part of your question as to location. As for if it was "worth it", it was to me. The Bose system really should have included a subwoofer. The under seat storage compartment will have to be removed. My ZR2 came with the basic storage tray. I didn't have any issues cutting it up. Had I not cut it up to use the part that I could, it would have just ended up in the attic or trash.
The Bose system has a sub. It's just not very powerful. It's under the center console.
It seems the kicker sub has gone MIA from GM accessories
Anything to watch out for with the install? Matt Ross made it seem pretty easy, but he also complained about the instructions and the small working space under the hood.
Does this sub integrate pretty seamlessly with the factory equipment? Is there any need for the additional 200 watt amp? 599 for just the sub seems like a pretty good deal opposed to the 1200+ with amp.
That package is for trucks without the Bose system. The Bose system already has an amplifier.
The "Bose" system in the ZR2 has paper cones, a terrible amp, and a weak subwoofer buried in the center console. The $600 for the add-on above includes the enclosure, speaker and amp. "This subwoofer system includes a high-efficiency 10" big-bass subwoofer with integrated 200-watt amplifier." If you want a quick plug and play solution, these are a nice addition. If you want a much more legit audio system in your truck you need to swap out all the speakers and do a high quality amp and woofer in the back. The head unit also has a very basic EQ. Any new system would massively benefit by adding a sound processor also. That swap out would cost $1500-$2k, but could run up to $4k + if you really max it out.
