If you'd like to try, I just removed the OEM active exhaust off my 2024 ZR2 with 475 miles.Just curious. Is it possible (sanely) to have a 2024 model like active exhaust on a 2022 ZR2 model?
if you can please share the pic(s) that will be great.If you'd like to try, I just removed the OEM active exhaust off my 2024 ZR2 with 475 miles.
A "true" sport mode exhaust outlet totally bypasses the muffler when the valve is open so you are having it sound like a straight pipe set-up...just spewing into the air. I would feel confident in saying that GM didn't do that because that would be LOUD!It's just a Y pipe with a valve on it that diverts some of the exhaust through a different section of the muffler. not sure what it looks like inside the muffler.
NoWonder if the sports mode can be retro-fitted to the '22 & '23's via OTA?
Minus the exhaust hardware, just the shift points and throttle response.
GM will never, IMPO, send out an OTA to install Sport Mode into a 22-23 ZR2. We all know what it is, and the ability to control the exhaust valve. No reason for GM to do it and I strongly doubt they will. They have enough shit that's broken that needs fixingMinus the exhaust hardware, just the shift points and throttle response.
You are right. Their updates have caused issues for many already. Sports mode may be more than just a software change (i.e. electronic hardware too).GM will never, IMPO, send out an OTA to install Sport Mode into a 22-23 ZR2. We all know what it is, and the ability to control the exhaust valve. No reason for GM to do it and I strongly doubt they will. They have enough shit that's broken that needs fixing
