Pricey is an understatement I realize it works, but what a RIP off for a $25 harness at best. You can very easily use a $10 cord off Amazon and a fuse tap. It's Super easy to get to the fuse panel and make the connection. All for under $20. This is what I did to mine. Basically a 10-15 minute job to head across the headliner and down the A-pillar to the passenger side fuse panel.I used this one because I wanted plug and play. A little pricey unless you want to break out the volt meter.
2022-24 1500 Refresh Chevrolet Silverado Refresh Radar Detector Harness
This harness is for installing your radar detector into your 2022-24, refresh Chevrolet Silverado 1500. This harness saves you from splicing and/or entering pins into your trucks wiring harness. Please select your appropriate mirror option when ordering as the harnesses are different. For...www.gen5diy.com
Any reason you didn't tap in to the rearview mirror vs running down the a-pillar?Pricey is an understatement I realize it works, but what a RIP off for a $25 harness at best. You can very easily use a $10 cord off Amazon and a fuse tap. It's Super easy to get to the fuse panel and make the connection. All for under $20. This is what I did to mine. Basically a 10-15 minute job to head across the headliner and down the A-pillar to the passenger side fuse panel.
I just don't care for mirror tapping and the cost to fuse tap it is only about $15 to run it to the fuse panel and about 10 minutes of time. Take two 10mm bolts out of the A-Pillar, pull it away...route the wire from the mirror across the headliner down the A-Pillar and right into the fuse panel. Literally about 10-15 minutes and you're done.Any reason you didn't tap in to the rearview mirror vs running down the a-pillar?
Mangoal Front 4K & Rear 1080P... https://www.amazon.com/dp/B0CKKNPY7K?ref=ppx_pop_mob_ap_shareHas anyone tapped in to the rearview mirror for a radar detector (or camera)? Any issues and/guidance you can provide?
Thank you.
I just installed the same exact camera in my 24 HD to try it out. So far, I really like it and love the OEM look. Bought the Parking Mode cable and easily ran it to the fuse panel.Mangoal Front 4K & Rear 1080P... https://www.amazon.com/dp/B0CKKNPY7K?ref=ppx_pop_mob_ap_share
I installed this one today, there are a few other OEM integrated cameras and radar detectors that come with harnesses, like Camfit and Mongoal. The Mongoal comes with 4 options (temp sensor, mirror dimmer, parking mode - OBD, fuse tap) I used the fuse tap for parking mode.
If you have any questions once you get it, PM me and I'll give you my cell. You won't be disappointed.Added to the cart, thanks guys! I've been kicking back and forth what I was going to do for a dashcam.
thank you good sir, will do!If you have any questions once you get it, PM me and I'll give you my cell. You won't be disappointed.
Be aware, some dealer on here denied a warranty claim for a failed Onstar module due to this.
In my books, the GEN5 is a mirror tap, just without the pins. A WAAAAAY overpriced harness that yields the same results.I bought the gen5diy. Made it easy compared to having to use a mirror tap. Piece of mind I wasn’t going to screw something up.
