Peak Bumper Spacer
I've been holding off upgrading the tires based on some folks having to cut and trim around the front bumper. Looks like peak just came out with bumper spacers - wondering if anyone has tried these yet. Assuming the spacer and the peak leveling kit, our trucks should be good to go for 35's?
Spacers
Spacers
Peak just released these, so i doubt anyone has tried them yet, aside from the people at Peak. Going to be giving Peak more of my 💵💵 for the 2.25” lift and Spacers now.
Cheaper than an ADD bumper! Anyone tried to just space out the bumper instead of cutting? Is it just that big of a pain?
Lots of posts with washers used to set front bumper forward. Ifvi was doing that, I'd consider using Deralin bushings.
Hi Guys,
I just put the 3/4" Peak spacers on yesterday. Pretty straight forward job. I did need to modify the bumper side bracket to make it line up with the bolts welded into the chassis. I had to extend factory hole out towards the outside pressed lip. Then of course the outside diameter of the big washer on the OEM bolt was too close to the lip so I had to grind a flat into it to make it fit.
J
