Or less lift. The 2.25 lift doe not help with the 35’s.You will need more than the peak 2.25 kit to clear 35s depending on offset. Be prepared to trim.
I’m not sure I follow you. Lift will help in clearance of larger tires.Or less lift. The 2.25 lift doe not help with the 35’s.
If you want a lift to clear 35’s you probably need an additional 4 inches. If you go less than 4 inches you will cut all the same things the rest of us have (discussed ad nauseam on this forum).I’m not sure I follow you. Lift will help in clearance of larger tires.
I am also running 35s but with -12 offset wheels and more than a 1/2” lift.If you want a lift to clear 35’s you probably need an additional 4 inches. If you go less than 4 inches you will cut all the same things the rest of us have (discussed ad nauseam on this forum).
My shoes are 35.1 tall and 11.5 wide. I have zero offset rims and a 1/2 level. Trimmed rear front wheel well plastic, removed the liner plate thing, shimmed the bumper, and cut and welded the crash bar. Another 1 and a half of height would have made zero difference.
I wish you all the luck though.
The suspension in my 22 has settled significantly since new. If I pull up to a new TB it looks lifted next to my truck and I have 34’s2024 ZR2 Bison 3l in Black.
Thanks for the add.
Looking into the Peak 2.25 lift.
I pulled up next to an identical 2024 bison with the 6.2 and it was at least 1.5” taller at the mirror? Any thoughts?
I had some questions about lift height when I first put the Peak spacer on the front. I definitely was not level.The suspension in my 22 has settled significantly since new. If I pull up to a new TB it looks lifted next to my truck and I have 34’s
No level/lift here. Stock general. But it is a commonality I see regularly.I had some questions about lift height when I first put the Peak spacer on the front. I definitely was not level.
I kind of feel the same, but haven't taken measurements. I also feel like the rear is softer. When I stab the throttle, it lifts thr front end more. I've only got 13k on mine.The suspension in my 22 has settled significantly since new. If I pull up to a new TB it looks lifted next to my truck and I have 34’s
Might be a good idea for that thread. I’ll have to get the tape measure outI kind of feel the same, but haven't taken measurements. I also feel like the rear is softer. When I stab the throttle, it lifts thr front end more. I've only got 13k on mine.
If I recall I think I posted the the measurements for my truck when I did my tires and wheels. If not, I may not have a basis for making a good assessment. Overall, I still feel like it rides good and has decent handling characteristics.Might be a good idea for that thread. I’ll have to get the tape measure out
