HVAC blend door actuator rattle
Anyone else have this happen to them? Seems to only happen when the truck is doing a system check before the ignition is pressed. Sounds like a blend door actuator skipping. Seems to go away when the truck is running.
Idk if it matters or not, but this is the first time I have had the truck in freezing conditions.
  • IMG_3094.mov
    20.8 MB
Been in plenty of freezing conditions, actual temps in the teens multiple times, and never had an issue.
Confirmed this only happens when it’s performing a system check. Once in the truck driving all the HVAC functions work properly.
With as many computers that are on these trucks I am hoping that it will show them something and I also have the video evidence.
Headed back south in the morning and will confirm if it goes away with warmer temps.
I have narrowed down that it is the actuator for the fresh air/recirc door. My it is stuck in fresh air only. Been breathing in all the exhaust fumes, road kill smell, and smoke for the last 6 hours.
