- Jan 1, 2023
- 3,487
- 7,302
Featured
- #21
When you're running a 12" DIC, trimming the bushes really won't make much of a differenceTrim the bushes make the tree look bigger![]()
LMFAOTrim the bushes make the tree look bigger![]()
i sat at my dealer for 2 hours waiting on this update. they went wireless and it failed. now manager says i need i notification from GM or i can pay $85. blow me!Does anyone have the code used for updating the DIC picture from a LTZ to a ZR2? I went to the dealer yesterday and as they did the fog light update and also the radio update ( didn't work still cuts out! ) and just like I figured they told me the Silverados are 'all the same' and that's as far as it went...
I know I read a thread here about this issue and I think some have had success?!
Pictures of the actual DIC would be really cool along with the update code!
Thanks!!
Yeah I ain't paying for it!i sat at my dealer for 2 hours waiting on this update. they went wireless and it failed. now manager says i need i notification from GM or i can pay $85. blow me!
F that broi sat at my dealer for 2 hours waiting on this update. they went wireless and it failed. now manager says i need i notification from GM or i can pay $85. blow me!
It CLEARLY tells them NOT to do the update wirelessly in the bulletini sat at my dealer for 2 hours waiting on this update. they went wireless and it failed. now manager says i need i notification from GM or i can pay $85. blow me!
im on it...It CLEARLY tells them NOT to do the update wirelessly in the bulletinThankfully, sounds like they didnāt brick you cluster doing it the incorrect way. Iād find another dealer that has a tech that can read.
Mine has the ZR2 image in the Tach. It only shows the ZR2 animation on the gauge side. The infotainment center is still the Chevy bowtie. If The dealership you go to says that they cannot do it give them the info that Q has posted and if they still seem clueless just save your time and go to another dealership. You can't fix stupid!Thanks for the picture!
Curious, after start up is the truck in the middle of the tach a ZR2 or LTZ?
A picture of that would be fantastic!
Roger that! Thanks for the pictures!Mine has the ZR2 image in the Tach. It only shows the ZR2 animation on the gauge side. The infotainment center is still the Chevy bowtie. If The dealership you go to says that they cannot do it give them the info that Q has posted and if they still seem clueless just save your time and go to another dealership. You can't fix stupid!![]()
Yeah that sounds right. The part wonāt fix it though, and should be exchange not through gm parts if itās the IPC itself. Iām a gm tech, so I play both sides. Iāve never been a fan of forums because the misinformation that spreads in them. I joined this one to see if everyone was experiencing the same issues I am. I had a 2500 pickup on my DIC but when I did the update on that bulletin earlier in this thread for a separate issue it changed to a Tahoe. It is a software issue that cannot be fixed. Replacing the module will require another program of the same calibration which in my experience will set the same stupid ass Tahoe. There will be many more software updates im sure. Iāll wait til my next one and if it changes Iāll let yāall know. Iām really more worried/tired of Alexa turning my fucking blower motor off every time I start to driveā¦So i was having the same problem of it showing a Tahoe. And i took it to my local dealer and they told me that some module was flashed for the Tahoe when it was updated last and that they called gm engineer and that the module wouldn't take a second update. So they are warranty claiming it for a new module and that it will have the zr2 startup screen along with the zr2 truck on the digital cluster. Just waiting for the part now with no eta on delivery due to the strikes
So how did some of the people report it being fixed with updates? Cause it drives me nuts with the Tahoe. The service department told me now this is just what they so i know grain of salt but that gm told them this part is vin specific and when it comes in will correct the problem right awayYeah that sounds right. The part wonāt fix it though, and should be exchange not through gm parts if itās the IPC itself. Iām a gm tech, so I play both sides. Iāve never been a fan of forums because the misinformation that spreads in them. I joined this one to see if everyone was experiencing the same issues I am. I had a 2500 pickup on my DIC but when I did the update on that bulletin earlier in this thread for a separate issue it changed to a Tahoe. It is a software issue that cannot be fixed. Replacing the module will require another program of the same calibration which in my experience will set the same stupid ass Tahoe. There will be many more software updates im sure. Iāll wait til my next one and if it changes Iāll let yāall know. Iām really more worried/tired of Alexa turning my fucking blower motor off every time I start to driveā¦
My dealership gave me confidence that they could get it lined out. They were pretty specific when explaining it. Because they were able to tell me when they applied the past update they selected the Tahoe flash. They also talked about how it would only take on flash or something. That why the need for the new part. They seemed pretty confident. But regardless. They are not charging meIf I recall correctly, in a previous thread about updating the driver info center to the ZR2 configuration there is a specific folder in the update software that contains the ZR2 graphics. I'm kind of glad my OCD has been keeping me from updating. I just know my local dealer would totally screw my truck up.
The software is vin specific, gm puts it out for us to program the module. if they put the wrong cal files for the truck or suv we have no way of changing that or knowing until itās programmed. Sometimes we replace radios and they say gmc until we program and it changes to Chevy itās all in the software. We can make selections of predetermined files depending on what we are programming or trying to fix with a program but only if available. Most calibrations are put in the database by whoever at gm does that. The ipc Can be programmed over and over unless it fails, which it isnāt since it works just wrong picture. Whenever I programmed mine I donāt remember being able to select anything in the calibration files but maybe thatās changed since. I havenāt had time to bring mine back in to try again. Maybe they know something I donāt and hope it fixes it, just giving my two cents.My dealership gave me confidence that they could get it lined out. They were pretty specific when explaining it. Because they were able to tell me when they applied the past update they selected the Tahoe flash. They also talked about how it would only take on flash or something. That why the need for the new part. They seemed pretty confident. But regardless. They are not charging me
Glad you got it figured out. What does āipcā stand for? I ask because a member may find it useful with their service writer or tech. Iād be in to update my driver information center if it would only update the truck graphic from the LTZ to ZR2. I think GM was a little short sighted mixing startup animations. I like how the Chevy animation goes from the DIC to the Radio.Ok definitive answer on the ipc update. The calibration file for my truck has changed. I installed the graphics calibration then the programming calibration and I now have a zr2 on the dic.
Instrument panel cluster. Thatās the Speedo and driver information center on these trucks. If you take yours to a dealer they need to program that graphics package for the ipc first then the regular programming for the same module after.Glad you got it figured out. What does āipcā stand for? I ask because a member may find it useful with their service writer or tech. Iād be in to update my driver information center if it would only update the truck graphic from the LTZ to ZR2. I think GM was a little short sighted mixing startup animations. I like how the Chevy animation goes from the DIC to the Radio.
