Back-Up Lighting Pods
securityguy
Well-known member
North Florida
OK...need some help here. The tail lights on the 2500HD are different than the 1500 series tail lights. My HD has builtin LED reverse lights and the animated rear blinkers/brake lights. I am going to purchase a special harness that requires tapping into both the "parking light" and the "reverse light" in the fully LED 2500HD tail lamp assemblies. Does any one have the information on what wire controls the parking light and what wire triggers the reverse lighting? @wutang61 ...copying you in your friend since you've been very helpful in the past and appear to have access to detailed information on our trucks. Thanks everyone!
This is the diagram for the left tail light. Right will be the same.
  • Tail lamp wiring .pdf
Maybe this will help you out.
  • 24_Silverado_2500-3500HD_Body_Builder_Manual_2023May11.pdf
No problem always willing to help. When I developed Pod holes, it was really just for myself to be able to put lights on the back of my truck, but I wanted to make sure when I brought it to Public that my wiring harness was the best it could be, when somebody’s hooking up to a seven pin, you don’t wanna mess around with wire taps or inferior product that’s why I developed my harness to be 100% plug and play.
I appreciate that! Please PM me so we can have an off-line conversation and I'll share my thoughts on what I want to do and see if I can make your harness work for my needs.
Anyone have a recommendation for an online third party FSM? I normally use AllData, but they only have them loaded in to 23MY.
