ZR2NYC
my onstar seems to be not working. anybody else? no nav and truck connected without internet. no response from onstar notification buttons in truck. they sent a refresh but nothing.
thanks for info @cef2lion just got off the phone with GM technical. trouble codes showing onstar module not responding. appt. set for next saturday for diagnostic. could be worse i guess. 14k miles on my 22.My onstar module failed recently on my 22. Same issues your seeing. Dealer had to order a replacement. When I picked it up everything was working again except the my Chevy app. Onstar comm services had to configure the new module to my truck then the app worked. Dealer service wasn’t aware that had been done.
You better call 911.View attachment 16384
I got this code whilst on the trails today
If I'm in Mexico do I call 9 juan juan?You better call 911.
Interested to see what that is.View attachment 16384
When this happened, did the Bluetooth and built in phone mic continue working? I want to disable my onstar, but have read when you do, you lose the mic for phone calls. That means you have to use speaker phone mode... I assuming if the onstar unit is bad it would have the same results if it were removed.my onstar seems to be not working. anybody else? no nav and truck connected without internet. no response from onstar notification buttons in truck. they sent a refresh but nothing.
np with bluetooth.When this happened, did the Bluetooth and built in phone mic continue working? I want to disable my onstar, but have read when you do, you lose the mic for phone calls. That means you have to use speaker phone mode... I assuming if the onstar unit is bad it would have the same results if it were removed.
Bluetooth worked fine.When this happened, did the Bluetooth and built in phone mic continue working? I want to disable my onstar, but have read when you do, you lose the mic for phone calls. That means you have to use speaker phone mode... I assuming if the onstar unit is bad it would have the same results if it were removed.
