- Feb 21, 2023
- 5,365
- 12,675
All the details and photos are here.Would you mind sharing the photos of how you trimmed the rear plastic fender protector?
https://www.chevyzr2.com/threads/method-305-nv-toyo-oc-rt-trail.623/
Do you have any photos of how they look on the truck?Some close ups of 295/70/18 Nitto Recon Grapplers on bone stock ZR2 (no level, no spacers, stock 18” rims). No apparent rubbing, but definitely close. 1.5-2” level would be ideal.
I didn’t trim anything at all, Passenger side carpet liner has some fraying on edge, but not from new tires.Looks like you trimmed the front bumper. Why not trim the rear plastic fender protection? I have some photos of how I did mine with 295s and it gives you the clearance you need in rear wheel well.
Very happy with them. I’ve had slightly smaller Recon’s on my 2021 Trailboss, but these are quieter on ZR2. Maybe less road noise with ZR2 in general.Do you have any photos of how they look on the truck?
Awesome looking truck. Glad to see there is no rubbing on a completely stock suspension and wheels. I plan to Go with that same brand and size tires now. Thanks for all the information.Very happy with them. I’ve had slightly smaller Recon’s on my 2021 Trailboss, but these are quieter on ZR2. Maybe less road noise with ZR2 in general.
ALLTRU,I didn’t trim anything at all, Passenger side carpet liner has some fraying on edge, but not from new tires.
Just do it and see what happens. Every picture I've seen with larger tires and spacers or negative offset rims looks like they would rub. Some say they don't and I believe everyone when they are sitting in the driveway with wheels straight.ALLTRU,
Still no problem with rubbing now that you have had the new size tires on for a while?
I'm running 35-37 psi on my Toyo Open Country RT Trails. Ran 38 and 40, but 37 was best balance for ride quality and handling. 35 psi was definitely a little softer, but 10 ply is still a heavy sidewall, so only so good on pavement. I'd run 40 to 50 psi if was towing long distance and had some weight.Curious what everyone is running on these 8 ply tires as all list 80 Psi on the sidewall.
My few talks with BFG mentioned about 45lbs being as low as they recommend.
Not sure what Nitto states. Hate to sacrifice ride quality with 50+ Psi in the tires on a half ton.
I haven’t noticed much as far as fuel mileage hit. As far as balancing, I just had them balanced and rotated (Discount Tire) and initially there was a little wobble that has seemingly worked itself out.Those look awesome! I’ve got the sand dune as well. Did fuel mileage take a hit with them? I know they are a fairly heave tire. Any troubles balancing?
Not true!! 70% of 295 is taller than 70% of 275! They're tallerMy stock tires are 275/70/18. All a 295/70/18 will do is give more road contact based on width...nothing to fill the wheel well. Did you mean to say something else?
Obviously didn’t read the thread. But thanks for the triple clarification.Not true!! 70% of 295 is taller than 70% of 275! They're taller
Looks good!!I don’t know about mid flaps?!?
Was actually going to post about these exact tires.Very minor changes but happy with outcome.. 285/70/18 Nitto ridge grappler and fuel blitz wheels +20 offset. The nittos ride much better and quieter than expected compared to the Goodyear MTs.
Agreed. I was going to wait as well but I was able to sell the stock wheels and tires for about 1500 so the new set only cost me about 1500. Well worth it to me especially going to the nittos being so much quieterWas actually going to post about these exact tires.
10lbs lighter then the 295’s and only .3” shorter and .25” narrower.
These things are the sweet spot for these trucks.
Exactly my plan once the GY’s wear a little more.
Thank you. No really thank you. Best news of my day. Because I absolutely hate driving on these MT’sAgreed. I was going to wait as well but I was able to sell the stock wheels and tires for about 1500 so the new set only cost me about 1500. Well worth it to me especially going to the nittos being so much quieter
no problem glad it helps someone. I honestly didn’t think the MTs were bad or loud as I came from driving a Jeep rubicon with 35 BFGs but then when I got the nittos I was shocked in the differenceThank you. No really thank you. Best news of my day. Because I absolutely hate driving on these MT’s
59 lbs each 34x11.50’s can’t go wrong.
BFGs were good tires in 1980s and 90s, but they haven't been relevant since Toyo, Mickey Thompson, and to some degree Nitto came along and changed the off road big tire game for the better.no problem glad it helps someone. I honestly didn’t think the MTs were bad or loud as I came from driving a Jeep rubicon with 35 BFGs but then when I got the nittos I was shocked in the difference
