- Nov 1, 2023
- 56
- 132
2024 Chevrolet 2500 Bison ditch/ pillar install complete. I used SDHQ mounting brackets and the awesome SPod BantamX with touchscreen controller, with strobe/flash/dim. This helped to make the install pretty clean.
Do you have any photos of where you ran the wires through the firewall? Looks great BTW!2024 Chevrolet 2500 Bison ditch/ pillar install complete. I used SDHQ mounting brackets and the awesome SPod BantamX with touchscreen controller, with strobe/flash/dim. This helped to make the install pretty clean.
Thanks love my set up. My installer used the attached service bulletin from GM to route the wires into the firewall. You have to cut into the rubber plenum in a small window on both the driver and passenger sides. Beware the small window won’t accommodate a lot of wires.Do you have any photos of where you ran the wires through the firewall? Looks great BTW!
Here is how I ran my wires from the battery to the cab. It utilizes a couple of plastic plugs under the drivers side carpet. Nice transition from wheel well, above frame, then up through floorboard.Do you have any photos of where you ran the wires through the firewall? Looks great BTW!
How do you like the BantamX so far? I'm torn between that and the Switchpros sp9100 right now.2024 Chevrolet 2500 Bison ditch/ pillar install complete. I used SDHQ mounting brackets and the awesome SPod BantamX with touchscreen controller, with strobe/flash/dim. This helped to make the install pretty clean.
