Wheel and tire pics
Looking for some pics of wheels and tires for my Slate Grey 2025 HD ZR2. Looking to go with preferably an 18 with a 37 if someone can confirm it will fit on a stock height setup or possible a 20” wheel. I’d like to stick with a tire that has a decent weight rating so I don’t have any issues pulling my 5th wheel.
Not exactly what you aksed but I was able to fit 38's and wrap them over a custom 20" daffodil style rim on this picture without having to cut the bumper or the liner.
Enjoy 😎🐝
If your looking for pics with stuff other than stock it may be hard to find. The Zr2 HD is relatively new... Most people I know of are running the stock wheels. You may find a few here and there but there really aint that much out there right now. However there are several ZR2 HDs running 37 inch tires on the stock wheels... which can be done easily without a lift. Hope this helps.
I went with some 18" Innov8 wheels wrapped in 37" Toyo At3s.
What offset is on those wheels? No center caps or would they not fit the hub cover? Are those new tires? The tread doesn't look very deep and in 37 the lugs usually look bigger.
Looks good with that bumper.
Thanks. The wheels are 18x9 with a 0 offset. The center caps should be here this week. I forgot to check the box when ordering. And the tires are new lol.
Are the tires 12.5 or 13.5 wide? I am disappointed in the availability of wheels with 0 offset or +12 offset in 8 lug. There just isn't much selection and stock.seems to be low too.
Axe, Have you tried Custom Offsets? I used DT for the truck, but just ordered a set of 38s and beadlocks for the Jeep and Custom Offsets smoked everyone mounted and delivered.
To check I just threw the truck in for bolt pattern and filtered for 18s and 0 to +18mm offset and they're showing 368 options, most in 9" width.
I have looked there before. I'll check then out again. Everyone seems to show the same products and about 363 of those wouldn't make it on my rig. Seems hard to find something that is not made primarily for looks. I want a wheel that looks beeefy and is HD for towing heavy too. That rules out a lot of those wispy looking multi spoke options.
I might go with a 20 inch wheel too, because I like the proportions better with a 37x13.50 tire.
I usually buy from a local dealer like 4 Wheel Parts or Discount or one of the lift shops. That way if I have an issue, I know they can deal with it locally.
They are 12.50 wide.
I certainly understand it's not the first place you'd look for something smaller than 26"s.
Check out Raceline, Method, and KMC. IIRC, Raceline and Method are still private while KMC is part of the huge conglomerate Wheel Pros/Hoonigan that is buying up all the mom and pops. Those three were my short list for real beadlocks on the Jeep and I'd expect a strong/quality product without making the jump to the super expensive stuff. You should be able to source all three through DT or a local shop, too.
If you really want something ugly, you can look at Black Rhino, another Wheel Pros brand.
I like one of the Black Rhino wheels, but they are a little too busy with the features, so they'd be hard to clean.
Weld has one that I sort of like, but the Method NV305 is still the only one I really like. It's no longer unique in terms of appearance, but they hold up well and are easy to clean.
I used to like RBP, but most of their stuff now looks like the pavement princess made a stop in the design studio. Their website is down with a "check back later, under new ownership" note.
Yeah. That picture shows the tread depth better. I'm considering the AT3s.
I used to run the MTs all the time and I liked them a lot. Tested them out on stock Bison wheels, but not enough clearance work +34 offset. I might go with the Trail RTs. Put them on my previous 2500HD just before I sold it to my boy and they look good. They tow really well and seem to work in most conditions They are chipping more on the 2500HD than on the 1500, so questioning durability on heavy rigs. The ones I have on my 1500 hardly look used after 13k miles.
