- Feb 21, 2023
- 5,379
- 12,735
I've been looking at my truck a little closer and noticed a few trim pieces that were not installed correctly.
The filler trim piece between the headlight and bumper is tilted out of place. It moves some, but doesn't seem to want to sit square with body panel. May have to come up through the back behind wheel well liner.
The trim piece between the roof and door frame is also tilted out of place towards the back of cab. I think it uses double sided tape, so had to be pulled and replaced. I may just leave it since I can't see it and it seems solid.
My 4x4 switch is also out of place and a little loose. I assume I can get up underneath the lower dash and push/snap it into place.
They need to tighten up that assembly line in Mexico.
