I’m sure just about any decent tire shop can swap it out for you.I learned that the HD ZR2/ Bisons don't have a TPMS sensor the spare. I got a screw in a tire and swapped it with the spare. The tire with the patched screw hole will now be my spare. How do I take out and place the sensor in the former spare?
Curious. I’m assuming the tire shop does a relearn for the fifth wheel when they rotate right? As chebbys only store an active 4.Just a screw in the tread? If you aren’t going to add a fifth TPMS sensor, why not just have the flat repaired? Probably save you the $25 or so to mess with the former spare.
I added the fifth sensor to allow for 5 tire rotations.
Yup. Confirmed with the tech at Discount when I swapped on the new tires and added the TPMS.Curious. I’m assuming the tire shop does a relearn for the fifth wheel when they rotate right? As chebbys only store an active 4.
