Skid Plate is bent
Don't forget the Zip Ties
I am on accessories site to order some for myself and did a quick search for you.
My search shows skid plate part is: GM # 85589118 and costs $382.03 and is "Out of Stock".
Still good idea to reach out to dealer and confirm for fitment before you order this part.
Yes this one you mentioned i need and also this one (84612142) which says it’s discontinued as per the attached image. I checked with my local dealer, and the prices are way high. Any idea on the discontinued item? How can i replace it then.
Stock skid plates on non bison are heinous - for pretty much any manufacturer.
I recommend replacing with Talon or Pinnacle offroad.
Talon even has plates for the diesel 1500s now
They aren't really skids, they are mostly fascia pieces and deflectors to keep road debris and incidental objects from making contact. Mostly sacrificial parts.
Yep.. sacrificial Just going to bang them out as best I can till I can afford some good steel ones or just waith and get the ADD front bumper and winch setup
When you pull it to bend it back, may as well Line X it. It'll cover up some of the rush and add rigidity.
Hey guys, well i had a rough off roading activity yesterday and my skid plate is bent. The bent plate is the second part right below the front part of the hood, its not the one at front where the recovery hooks neither its the one shielding the engine, anyone knows its part number?
84612142
