landpilot
- Jun 14, 2022
- 211
- 346
Featured
- #21
I too appreciate your honest review. The more I look at the video, the more I actually do like the bar, even though it's kind of expensive (although Amazon has it for $279, but it doesn't say if it includes the remote and it's not sold by Putco).The light output is great and it is pretty cool that it lights up the entire honeycomb as opposed to just a bar. That being said there is no way this bar is meant to be used on this grill there is really no good way I was able to find to mount it outside the grill or inside the grill. I have mine attached with 2 zipties on either end nothing in the middle. 1 ziptie holds it up and 1 zipetie holds in the in center on each side. The bar I think is light enough that this should be fine but we will see. Attached is a pic which shows the single ziptie on each side that is around the front of the grill. In my opinion if you dont know exactly where to look you wouldn't even see it.
However like I said they use this truck for the AD for this product but it is in no way for this truck. There is no good way to mount it that I was able to find and the AD video also shows that the DRL's on the truck trigger the stock sequential series and also the Bar goes off with it at the same time. There is actually no way to make that happen without rewiring the whole truck. The DRL's on the truck don't have their own fuse so there is no way to tap without constant power from the headlight fuse. So you have to tap a fuse that only has ignition power or else the bar is always on. Since our stock DRL's on do the sequence when you hit unlock on the fob not when you start the truck these things can't happen at the same time.
That was long winded I hope it makes sense, anyone feel free to DM me with any questions. Overall I like the bar but I feel like most people would probably be unhappy with it for roughly $400.
I wonder if the Putco team could explain how the wired it into the DRLs like that? I think I will reach out to them and ask.
