Engine Oil Hot
Was driving on the interstate today when all of a sudden I get a a engine oil hot warning on the dash. The exact warning was
“ Engine Oil Hot: Idle Engine”
A bit weird since I still have 35% on my oil life and never had this problem before. The engine also started to make a loud noise as if I’m pulling while just cruising.
I pulled over and turned off the car. It won’t start no matter what I do and oil temperature has come down but still won’t start.
No leaks on the bottom when I checked fearing a coolant leak.
Anyone had this happen and what was the cause. I fear that my lifters have failed which might have made the oil hot?
Currently waiting for Triple A to tow but this is kinda ridiculous to be happening on a truck with less 40 k miles and that costs 70k.
SMH….
SMH….
If you hit the Onstar button they can run a diagnostic over the air and send it to the dealer it's going to. I had this done when my HC crapped out on me in the middle of nowhere.
You could have main and rod bearings going bad. Small metal particles could have clogged oil cooler lines. Not saying that’s the case, just a thought of what could be wrong. My 22 had bearing failure at 14k would still start and run.
SMH….
She's cooked, smoked that main crank bearing or con rod bearing. Lots of threads on that issue if you do a quick search. Good luck with your motor replacement.
The babyMAX WEASEL Strikes again.
Damn... I fearing that but it really sounds like shes cooked..
Happy that I still have warranty I guess.. hoping that they give me a loaner in the meantime.
Definitely trading in for a Raptor after this. Chevy has left a bad taste in my mouth..
Sorry, that sucks man. Did you watch them load it on the rollback? Hopefully they didn't just drag it on.
Need a tow truck with a rollback bed and someone that knows how to use it. No dollies, skids or dragging required. This guy's got a few videos loading Silverados and talks about the neutral issue. He says it's the most common truck he tows. Cited the FPCM in this video and one other.
There was a post a while back about car wash mode. Would that even have been an option?
Post in thread 'Electronic Shifter'
https://www.chevyzr2.com/threads/electronic-shifter.1061/post-25983
Having had my 2022 towed twice, there is only one sure fire way to get them in to neutral when it won’t start. Block the rear tires, disconnect the rear wheel electronic emergency brake (both sides), get vise grips or a 5/16” wrench and some zip ties. Crawl under it with the truck ignition on. Take the 5/16” wrench, place it on the flats of the shifter shaft on the driver’s side of the transmission and turn it counter clockwise towards the transmission lines. Then zip tie the wrench to the transmission lines to hold it in place.
What a time to be alive!
Just hope the 2024 with the Duramax I traded for doesn’t use the same FPCM🤞🏻
It might have a lift pump and a fuel pump, the HD does, but never looked at the 3.0 L.
