- Apr 12, 2023
- 46
- 78
Nice, hopefully it’s not too low for you coming from the S type. Having had both sounds ,let us know your thoughts on it if you can.im at dealer now swapping out Borla "S" type for Touring muffler.
Is this part of the quest for the truck to not sound like the space shuttle launch on start up?im at dealer now swapping out Borla "S" type for Touring muffler.
Dealer installed the Touring muffler. sounds great....too me. its what it should have been from the start, one level up from stock. sound like music is subjective. if you are looking for a stock start up and a growl when you pass, touring muffler is perfect. zero drone at speed. thanks alot for all the help. great forum.Nice, hopefully it’s not too low for you coming from the S type. Having had both sounds ,let us know your thoughts on it if you can.
They charged me 100.00 and added it to my vin# so it's covered under the factory warranty as well.Curious to what dealers are charging you guys to install this system?
i bought the accessory at point of sale and was charged $140 for complete swap. i just paid $70 for muffler swap.Curious to what dealers are charging you guys to install this system?
Glad you finally got what you were after!Dealer installed the Touring muffler. sounds great....too me. its what it should have been from the start, one level up from stock. sound like music is subjective. if you are looking for a stock start up and a growl when you pass, touring muffler is perfect. zero drone at speed. thanks alot for all the help. great forum.
its now the accessory system i purchased from the muffler back with a new front pipe and of course the new muffler. seemless fit. Borla did the right thing. it sounds exactly what i was looking for.Glad you finally got what you were after!
So did you end up using the stock exhaust system with just the touring muffler or was it still a complete system?
Was there a part number associated with what you got?its now the accessory system i purchased from the muffler back with a new front pipe and of course the new muffler. seemless fit. Borla did the right thing. it sounds exactly what i was looking for.
gimme a minute.Was there a part number associated with what you got?
Also interested in a muffler with resonators still attached. I don’t want to irritate the older neighbors but I still want to make the truck sound like it’s not an EV.its now the accessory system i purchased from the muffler back with a new front pipe and of course the new muffler. seemless fit. Borla did the right thing. it sounds exactly what i was looking for.
gm borla accessory part number.Was there a part number associated with what you got?
This is the part number for the front pipe and muffler sent by Borla?gm borla accessory part number.
no. im not sure of part numbers for the replacement parts. it came in a generic box. i will have to look. i misunderstood.This is the part number for the front pipe and muffler sent by Borla?
No worries. Wanted to be able to call them up and give a part number rather than describe the situation and maybe get the right replacement part.no. im not sure of part numbers for the replacement parts. it came in a generic box. i will have to look. i misunderstood.
these were numbers on box that was shipped. call borla to make sure what these numbers are. hope it helps.Was there a part number associated with what you got?
Just reading through this thread - did you ever figure out the source of the vibration? I am having the same issue sporadically.Update. That was not the issue. Back to figuring out which damn piece of heat shielding is vibrating at low rpm.
I did. The back section was too close to the heat shield around the spare tire. Driver side was making contact at low vibrational speeds. Dropped the tire and easily bent the shield further away.Just reading through this thread - did you ever figure out the source of the vibration? I am having the same issue sporadically.
