I just left JBER in 2020. Iād like some details on the exhaust. I donāt want to dump $1500 right now considering Iāve had the truck for a week.Well, joined a little after Iāve done a few minor things;
-Borla Attack Muffler single dump in front of the passenger rear wheel (absolutely beastly)
-K&N Black Hawk cold air intake system
-Blacked out Badges for disco points
-Ronin Bullet antenna, cuz āmurca
-method 305 17ās 0 offset with BFG ATās 35x12.5 (hopefully no spacers needed)
-Camburg KINETIC UCA heim joint and uniball cup (max caster is required when aligning)
-KING 2.5ā shocks all around with compression adjusters on all four reservoirs
-clear bra and ceramic coated, because⦠well⦠Alaska.
Solo garage install for the UCAās and shocks took about 8 hours in total. Biggest pain was mounting the reservoirs (there was a factory document inside the frame blocking a hole for the mount⦠lol)
Everything torqued to spec which probably took the longest, especially to reach the third bolt on top of the front shock bucketsā¦
Tires and wheels will be put together and balanced tomorrow for pick up, and Iāll be bringing it to get the alignment Wednesday.
Have to get the wheels and tires on at the house since the stock set up is thisclose to rubbing at static heightā¦
Should be all good to go Wednesday and Iām pretty excited to get it going and dial the shocks in!
A lot of members here just bought the muffler and had it welded on. The most budget friendly way to go.I just left JBER in 2020. Iād like some details on the exhaust. I donāt want to dump $1500 right now considering Iāve had the truck for a week.
Just the Borla attack muffler and $150 to have the massive baffler cut out and the Borla welded in. About $400 in total costI just left JBER in 2020. Iād like some details on the exhaust. I donāt want to dump $1500 right now considering Iāve had the truck for a week.
