Backup lights--2024 Chevy HD 4wd ZR2 diesel
I thought I would order some led backup light replacements so that it actually throws some light behind to back up in the dark--I went to the usual site, where I bought them in the past, and put in my vehicle info--I ordered what it suggested--When I tried to install them I found out that there are no replaceable bulbs in the tail light assembly on my truck-it is all just one power supply unit and embedded led modules for all of the lights--i went to another site for their nice hitch inserts with good lights that function through the wiring harness-running, brake, and backup--well they don't have one for my truck--but you can get them for most other Chevy HD trucks-- but not ZR2 ??
anyone have a suggestion--
Check the Pod Holes website and see if they have a 2500 HD kit. I put one on my 1500 and its great.
I have the Bison edition 2500HD and ran a separate switch and relay for rear lights. If you have the standard bumper, Baja Designs makes some nice lights that will. flush mount in the rear bumper if you cut some squares out with the template they provide.
My boy used a wireless remote for his light switch and it works really well. I would use that kit if I was doing it again.
definitely following this as backing up to my trailer at night is a bit of a challenge
I believe it depends on which taillights you have. I also have a 2024 ZR2HD and was able to replace my back-up lights with better ones, but when I bought my truck the fancier taillights were not available due to a parts shortage so I ended up the the standard ones.
