Has anyone installed an auto stop disable harness or fuse kit? I wish this feature didn’t exist… yes I know you can hit the button every time, but I don’t want to
I have the SmartSopStart on my baby max. Super easy to install, and works flawlessly.I have a minimax engine in my ZR2 so I don’t think the Range AFM would work. Thanks for the rec though.
I have one that I replaced with the Range module. If you DM me your name and address, I'll send it to you no cost.Has anyone installed an auto stop disable harness or fuse kit? I wish this feature didn’t exist… yes I know you can hit the button every time, but I don’t want to
@IowathumperLooks like this only goes up to 2022 Chevy ZR2 That correct?
I have been looking to get one of these, what type do you and what made you remove it and switch to the Range module?I have one that I replaced with the Range module. If you DM me your name and address, I'll send it to you no cost.
Why the hell is a diesel powering down, there's nothing worse for a diesel motor than shutting it off frequently.
All of themLooks like this only goes up to 2022 Chevy ZR2 That correct?
For those who have installed the RA007 For 2022.5 - 2025 Chevy trucks.Just installed the RANGE DFM/auto start stop module and it works perfectly.
It’s been discussed in a couple threads on this forum. Essentially, it does not 100% stop cylinder deactivation, there appears to be certain situations where cylinders may still deactivate. It appears to be very minimal and doesn’t appear to cause any actual “issues”.For those who have installed the RA007 For 2022.5 - 2025 Chevy trucks.
Question? They mention you might have
Any issues or above?
- Some applications may still encounter 0-Cylinder Mode while coasting when 0% throttle input is detected at the ECM
I have this one. Easy to install and worked perfectly to stop auto stop. I ended up going to the range module cause it dod this as well disabling the DFM cylinders dropping, which improves shifting and performance slightly for a more responsive feel to how the power gets to the wheels.I have been looking to get one of these, what type do you and what made you remove it and switch to the Range module?
No issues with mine. I would highly recommend this product.For those who have installed the RA007 For 2022.5 - 2025 Chevy trucks.
The exhaust makes a little blurb sound as the engine fires back up right before you come to a stop but that’s about it. Like mentioned it has been discussed and I think range even said that it’s something different than dfm.For those who have installed the RA007 For 2022.5 - 2025 Chevy trucks.
