I bought this from PCB Techart. Works well. Just need to put some double sided tape on it, as it knock it out sometimes.Hello, I used to have the same problem. I found the solution by putting a piece that serves as a riser on the wireless charger.
Finally I found this and I bought it:
Chevy Silverado/GMC Sierra charging adapter
Upgrade your Chevy Silverado or GMC Sierra's charging capabilities with our wireless charging adapters. Our adapters are compatible with all major phone models and are easy to install. Enjoy the convenience of cordless charging while on the go.www.pcbtechart.com
You can do a test before you buy it by putting a piece that serves as a spacer of at least 1 inch you can use foam, wood, plastic but don't use metal.
I am wondering if the dealer will do anything as well. Ive noticed that if I pull the pad off it works better tooI have a piece of foam wedged in there, but even with that, I will get the orange icon. I slide the phone out about an inch, then put it back in. Usually between three or four times cycling it when it turns orange and then it'll stay green. Not ideal, but this is what's working for me... I notice the issue much more often when my battery is below 50%.
They won't.I am wondering if the dealer will do anything as well. Ive noticed that if I pull the pad off it works better too
