Is topdon a good brand? I figured it would cost more. Just not sure the difference between brands or what’s good or not.For ABS brake bleeding you’re going to need a bidirectional OBD device. If you’re on TikTok, they’re always advertising a TopDon bidirectional OBD device. A bidirectional device is going to cost slightly more than a plain OBD code reader.
I have no idea about Topdon’s quality. I only use plug in OBD readers to read and clear coats. I have a Launch scan tool that requires subscription updates for a bidirectional device.Is topdon a good brand? I figured it would cost more. Just not sure the difference between brands or what’s good or not.
I use this one and it is bidirectional so long as the app your using is capable. I use the TorquePro and OBD apps and it does quite a bit, but never messed with brake bleed.
Amazon.com
a.co
Good choice!If you mean Torque Car Pro it is on iOS. It has crap reviews though. I remember using it years ago when I had android and it being ok.
I may put off this purchase in place of having the truck detailed/paint corrected to get the water marks removed then have it ceramic coated.
A friend went looking for torque on the apple app store and it wasn't coming back in his search....If you mean Torque Car Pro it is on iOS. It has crap reviews though. I remember using it years ago when I had android and it being ok.
