Negative Offset Tire Suggestions
I’m looking to purchase Black Rhinos 17x8.5 with a -10 offset. I was wondering what would be the biggest size tires I could go with without doing any suspension mods or trimming? Any suggestions would be appreciated! Thanks guys!
Your probably going to trim with any negative offset wheels. You might be able to minimize it if you stay with 33-33.5 inch high tires and narrow rim and tire width.
I would get whatever tires you want and trim as necessary. I have a detailed thread about it. Trimming plastics on rear of wheel wells is simple and you can't really tell. If you don't want to trim front bumper, then you can add spacers to move it forward a bit. Others have posted pictures of that mod.
i put 2" spacers on stock tires and rims. it still rubs. I even tapped a hole in the "crash bar" and used some extra fender liner screws from my last silverado to tighten up all the extra carpet and plastic. still rubs on driver side at full turn. that stupid crash bar is probably the reason the 1500's come with 33's and the colorado/canyons can fit 35's on the ZR2 packages
