Feido82
Had the truck (2024 Bison 3.0L) in for check engine light, EGR was the code, dealership ran tests, cleared code, test drove, no light, not sure the issue, but will continue to update the thread if problems persist.
If the codes continue, I'll be pressing to get the ecm replaced.Good luck! I just love it when you take your vehicle in knowing it has an issue and all you can get out of them is "cleared code" "could not duplicate issue".
I ran into the same thing with my trailer light control module. Tech cleared the stored code in the BCM and it did not come back so it was "Fixed" (code will only pop if you hook up a trailer). I used my volt meter and had to show the service manager that the tail lights were still getting constant 12v even with the key off not once, not twice, but three times before they finally condemned the module. Wasted my time on three occasions before they made it right and changed the part even though when it took it in the first time I told them what it needed.
