35s
Can anyone who got 35s, while finding a way to keep the Multimatic dampers on the 1500 ZR2, tell me how they did it? I know the 2027 is getting 35s and while I like the concept renders, I do not like the updated interiors and I am investing in my 2022 1500 ZR2.
There's some posts on this topic if you do a quick search. There are some lifts / level kits readily available. The Peak suspension kits are popular.
I run 295s that are almost 35 inch with minor trimming.
Thanks! Still figuring out how to work this site but am about to give that a shot.
285/75/r18 which is pretty much a 35x11.5 will fit stock with potential minor trimming. I didn't have to trim mine at all- however I am running an aftermarket bumper.
I would assume they'd fit with the stock bumper too- but you may need to cut a bit of the inside front liner.
No plastic or metal trimming would be required.
A four inch lift would allow you to run a 35 without trimming, depending on the offset of your wheel. There are several companies making them, that are designed for the use of the multimatic shocks.
